It crashes with this error
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400dae1c PS : 0x00060930 A0 : 0x800de45f A1 : 0x3ffca800
0x400dae1c: _lv_memcpy_small at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/../lv_font/../lv_misc/lv_mem.h:219
(inlined by) lv_area_copy at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/../lv_font/../lv_misc/lv_area.h:99
(inlined by) lv_obj_get_coords at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_obj.c:2241
A2 : 0x000000a6 A3 : 0x3ffca838 A4 : 0x00000009 A5 : 0x00000000
A6 : 0x00000008 A7 : 0x3ffb7c18 A8 : 0x00000008 A9 : 0x3ffca7e0
A10 : 0x00000001 A11 : 0x0000005d A12 : 0x00000004 A13 : 0x00000c00
A14 : 0x00000042 A15 : 0x3ffca7d8 SAR : 0x0000001f EXCCAUSE: 0x0000001c
EXCVADDR: 0x000000a6 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace:0x400dae19:0x3ffca800 0x400de45c:0x3ffca820 0x400de49b:0x3ffca870 0x400de4d9:0x3ffca8c0 0x400de7e8:0x3ffca8e0 0x400de96d:0x3ffca960 0x400dea56:0x3ffca990 0x400deab8:0x3ffca9b0 0x400e9345:0x3ffca9e0 0x400e9430:0x3ffcaa00 0x400d5a60:0x3ffcaa20 0x40088bc5:0x3ffcaa50
0x400dae19: lv_obj_get_coords at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_obj.c:2241 (discriminator 2)
0x400de45c: lv_refr_obj at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_refr.c:721
0x400de49b: lv_refr_obj at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_refr.c:734
0x400de4d9: lv_refr_obj_and_children at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_refr.c:636
0x400de7e8: lv_refr_area_part at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_refr.c:567
0x400de96d: lv_refr_area at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_refr.c:478 (discriminator 2)
0x400dea56: lv_refr_areas at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_refr.c:400
0x400deab8: _lv_disp_refr_task at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_core/lv_refr.c:199
0x400e9345: lv_task_exec at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_misc/lv_task.c:386 (discriminator 1)
0x400e9430: lv_task_handler at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../components/lv_port_esp32/components/lvgl/src/lv_misc/lv_task.c:134
0x400d5a60: lvgl_gui_task at /home/vedant/Programming/projects/open-authenticator/open-authenticator-app/build/../main/lvgl_gui.c:343 (discriminator 1)
0x40088bc5: vPortTaskWrapper at /home/vedant/esp/esp-idf/components/freertos/xtensa/port.c:143
This is my function
static void lvgl_gui_init_obj()
scr1 = lv_obj_create(NULL, NULL);
scr2 = lv_obj_create(NULL, NULL);
scr3[0] = lv_obj_create(NULL, NULL);
scr3[1] = lv_obj_create(NULL, NULL);
scr4[0] = lv_obj_create(NULL, NULL);
scr4[1] = lv_obj_create(NULL, NULL);
scr4[2] = lv_obj_create(NULL, NULL);
dummy_obj_event_handler = lv_obj_create(NULL, NULL);
label_battery_group_root = lv_label_create(scr1, NULL);
label_alias_group_1 = lv_label_create(scr1, NULL);
bar_time_progress_group1 = lv_bar_create(scr1, NULL);
label_code_group_1 = lv_label_create(scr1, NULL);
label_time_group_2 = lv_label_create(scr2, NULL);
label_sync_time_group_3 = lv_label_create(scr3[0], NULL);
label_sync_time_spinner_group_3 = lv_spinner_create(scr3[1], NULL);
label_setting_group_4 = lv_label_create(scr4[0], NULL);
label_ap_name_group_4_1 = lv_label_create(scr4[1], NULL);
label_ap_pass_group_4_1 = lv_label_create(scr4[1], NULL);
label_ip_addr_group_4_2 = lv_label_create(scr4[2], NULL);
image_qr_code_group_4_2 = lv_img_create(scr4[2], NULL);
lv_label_set_text(label_battery_group_root, " ");
lv_label_set_text(label_alias_group_1, " ");
lv_label_set_text(label_code_group_1, " ");
lv_label_set_text(label_time_group_2, "\t\t\t\t" SYMBOL_CLOCK "\nTIME");
lv_label_set_text(label_sync_time_group_3, "\t\t\t\t" LV_SYMBOL_LOOP "\nSYNC TIME");
lv_label_set_text(label_setting_group_4, "\t\t\t\t" LV_SYMBOL_SETTINGS "\nSETTINGS");
lv_label_set_text(label_ap_name_group_4_1, "connect to open-authenticator " LV_SYMBOL_WIFI);
lv_label_set_text(label_ap_pass_group_4_1, " ");
lv_label_set_text(label_ip_addr_group_4_2, " ");
lv_obj_align(label_time_group_2, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_align(label_sync_time_group_3, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_align(label_setting_group_4, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_align(label_ap_name_group_4_1, NULL, LV_ALIGN_IN_TOP_MID, 0, 0);
lv_obj_align(label_ap_pass_group_4_1, NULL, LV_ALIGN_IN_BOTTOM_MID, 0, 0);
// add group_4_2 elements too
lv_obj_set_size(bar_time_progress_group1, 128, 10);
lv_bar_set_type(bar_time_progress_group1, LV_BAR_TYPE_SYMMETRICAL);
lv_obj_align(bar_time_progress_group1, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_size(label_sync_time_spinner_group_3, 60, 60);
lv_spinner_set_type(label_sync_time_spinner_group_3, LV_SPINNER_TYPE_CONSTANT_ARC);
lv_spinner_set_arc_length(label_sync_time_group_3, 150);
lv_obj_set_style_local_line_width(label_sync_time_spinner_group_3, LV_SPINNER_PART_INDIC, LV_STATE_DEFAULT, 5);
lv_obj_set_style_local_bg_opa(label_sync_time_spinner_group_3, LV_ARC_PART_BG, LV_STATE_DEFAULT, 0);
lv_obj_set_style_local_radius(label_sync_time_spinner_group_3, LV_ARC_PART_BG, LV_STATE_DEFAULT, lv_obj_get_width(label_sync_time_spinner_group_3) / 2);
lv_obj_align(label_sync_time_spinner_group_3, NULL, LV_ALIGN_CENTER, 0, 0);
lv_label_set_long_mode(label_ap_name_group_4_1, LV_LABEL_LONG_SROLL_CIRC);
lv_obj_set_width(label_ap_name_group_4_1, 128);
group_root = lv_group_create();
lv_group_add_obj(group_root, dummy_obj_event_handler);
lv_group_add_obj(group_root, label_alias_group_1);
lv_group_add_obj(group_root, bar_time_progress_group1);
lv_group_add_obj(group_root, label_code_group_1);
lv_group_add_obj(group_root, label_time_group_2);
lv_group_add_obj(group_root, label_sync_time_group_3);
lv_group_add_obj(group_root, label_sync_time_spinner_group_3);
lv_group_add_obj(group_root, label_setting_group_4);
lv_group_add_obj(group_root, label_ap_name_group_4_1);
lv_group_add_obj(group_root, label_ap_pass_group_4_1);
lv_group_add_obj(group_root, label_ip_addr_group_4_2);
lv_group_add_obj(group_root, image_qr_code_group_4_2);
lv_obj_set_event_cb(dummy_obj_event_handler, switch_event_handler_cb);
lv_indev_set_group(my_indev, group_root);
lv_scr_load_anim(scr1, LV_SCR_LOAD_ANIM_FADE_ON, 100, 100, false);
