Device with Linux kernel, using gcc10 for compilation
v7.8.1 (latest master)
I’d like to understand how to fix a bug in my program. Currently, if I press any key other than KEY_ENTER or KEY_UP, it is not translated to my event handler as an event, despite evdev driver from lv_drivers translating the keys properly.
- Adding debug output to evdev LVGL driver to check if keys are translated.
- Trying two solutions to get a pressed key (check code section)
This code is a shortened version of the actual code. Note that:
- it won’t work in simulator
- original code works in simulator, but doesn’t work with evdev
The full code is stored at https://github.com/HenriDellal/mobile-recovery-lvgl
#include "lv_drv_conf.h"
#include "device_config.h"
#include "lvgl/lvgl.h"
#include "lv_drivers/display/fbdev.h"
#include "lv_drivers/indev/evdev.h"
#include <dirent.h>
#include <fcntl.h>
#include <stdio.h>
#include <threads.h>
#include <unistd.h>
static lv_indev_drv_t kp_drv;
static lv_indev_t * kp_indev;
static lv_obj_t * options;
static void mm_event_handler(lv_obj_t * obj, lv_event_t ev) {
uint32_t key = lv_indev_get_key(kp_indev);
// other non-working solution is
// uint32_t * key = (uint32_t *) lv_event_get_data();
printf("mm_event: %d\n", key);
static void open_menu(lv_event_cb_t ev_handler) {
lv_list_clean(options);
lv_obj_t * list_btn;
list_btn = lv_list_add_btn(options, NULL, "First");
lv_obj_set_event_cb(list_btn, ev_handler);
lv_list_focus_btn(options, list_btn);
list_btn = lv_list_add_btn(options, NULL, "Second");
list_btn = lv_list_add_btn(options, NULL, "Third");
void tick_thrd() {
for(;;) {
usleep(5); // Sleep for 5 milliseconds
lv_tick_inc(5); // Tell LVGL that 5 milliseconds have passed
lv_task_handler(); // Tell LVGL to do its stuff
int main() {
thrd_t tick_thrd_t;
fbdev_init();
evdev_init();
// Set up buffer
static lv_color_t buf[LV_HOR_RES_MAX * LV_VER_RES_MAX];
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * LV_VER_RES_MAX);
// Set up display
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.buffer = &disp_buf;
// Setup keyboard driver
lv_indev_drv_init(&kp_drv);
kp_drv.type = LV_INDEV_TYPE_KEYPAD;
kp_drv.read_cb = evdev_read;
kp_indev = lv_indev_drv_register(&kp_drv);
lv_group_t * group = lv_group_create();
lv_indev_set_group(kp_indev, group);
// Create "ticking" thread
thrd_create(&tick_thrd_t, (thrd_start_t)tick_thrd, NULL);
options = lv_list_create(lv_scr_act(), NULL);
lv_group_add_obj(group, options);
open_menu(mm_event_handler);
lv_obj_set_event_cb(options, mm_event_handler);
// Sleep forever
for(;;)
usleep(5000);
