The image not rendered properly to “ui_Image2”.
-ESP32-S3 (WT32-S3-Wrover)
-Arduino IDE
8.3.4
Display base64 decoded message on screen
//This code receive an Mqtt base64 message and decoded the message before displaying it to “ui_Image2” generated using Squareline Studio.
void messageArrived(char* topic, byte* payload, unsigned int length) {
String message = “”;
for (int i = 0; i < length; i++) {
message += (char)payload[i];
message.trim();
Serial.println("Received message: " + message);
// Decode the base64 message
size_t decodedSize;
uint8_t* decodedData = base64_decode((const unsigned char*)message.c_str(), message.length(), &decodedSize);
const lv_img_dsc_t* TemporaryImage = new lv_img_dsc_t({
LV_IMG_CF_TRUE_COLOR, //Header CF
0, // header.alwayszero
2, // Unknown
320, // Width
240, // height
decodedSize, // data size
decodedData // data
lv_img_set_src(ui_Image2, TemporaryImage);
