Hi everyone,
First of all thanks for this very good library.
I’m thinking about implementing a dynamic bar graph.
I have no idea how to do it:
From a chart obj ?
Just create my objects and draw a children obj, which got a floating height, into the parent.
Is an animation possible on this kind of graph ?
EDIT:
Is that possible to create an obj with a negative height ?
For example:
lv_obj_set_size(toto, 50U, -50U);
which means, if i set the position of toto into the center of my screen it will create a bottom line at x=50 then he will draw above. Which can allow me to have an x fixed value for a bar graph and use body.grad_color in the other direction for example. I tried that code but it doesnt draw anything.
ie:
Thanks,
CB
