I am currently using the line chart example in LVGL V8.0. I realised that the max value of for the plots and Y-axis is 2 bytes but I need to display values greater than 100,000 as 2^(16)-1 gives a range of -32,768 to 32,767 only. How do I change it so that it can show values greater than 2 bytes? thank you for your help
stm32f769i-disco
V8.0
I would like to display large values >100,000 on a line chart
I have tried to change the plot values to a value <2 bytes and it displays correctly. However, when a value e.g., 100,000 is entered, the value shown is negative as there is buffer overflow.
void lv_example_chart_1(void)
/*Create a chart*/
lv_obj_t * chart;
chart = lv_chart_create(lv_scr_act());
lv_obj_set_size(chart, 200, 150);
lv_obj_center(chart);
lv_chart_set_type(chart, LV_CHART_TYPE_LINE); /*Show lines and points too*/
lv_chart_set_range(chart, LV_CHART_AXIS_SECONDARY_Y, 0, 100000); //shows negative value
lv_chart_series_t * ser2 = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_GREEN), LV_CHART_AXIS_SECONDARY_Y);
/*Directly set points on 'ser2'*/
ser2->y_points[0] = 90;
ser2->y_points[1] = 100000; //shows negative value
ser2->y_points[2] = 65;
ser2->y_points[3] = 65;
ser2->y_points[4] = 65;
ser2->y_points[5] = 65;
ser2->y_points[6] = 65;
ser2->y_points[7] = 65;
ser2->y_points[8] = 65;
ser2->y_points[9] = 65;
lv_chart_refresh(chart); /*Required after direct set*/
