How to accelerate the speed of LVGL canvas drawing
Hello, There are a MIPI camera and a MIPI LCD on my board. I want to display the camera frames on the LCD while also showing some labels. I have successfully achieved this using lv_canvas_set_buffer, but the camera frames appear very laggy, with CPU usage above 80% and FPS only at 5.
This may be due to the high computational load of converting camera frames to lv_canvas. Is there any way to make the camera frames display more smoothly?
NXP RT1176
8.3.5
Make the camera frames look smooth.
On my previous board, I had two SDRAM modules connected in parallel, achieving a speed of 800MB/s. Additionally, the code was running from the SDRAM. Under this configuration, the camera display was very smooth. However, in my current setup, I am using a HyperRAM with a speed of 400MB/s, and the code is running from a NOR Flash with a speed of 200MB/s.
On the SDRAM board, without enabling any compiler optimizations, the CPU usage was around 80%. Enabling VGLITE reduced the CPU usage to just over 40% and resulted in a very smooth display. However, on the current board, I have already set the compiler optimization level to -O3, and the CPU usage is at 90%. Even after enabling VGLITE, the CPU usage only decreases to around 80%. In this scenario, which factor has a greater impact on the performance, the slower NOR Flash or the slower HyperRAM?
My idea is to manually link some frequently called and time-consuming functions to the internal RAM in order to speed up the conversion process. But I am unsure which functions to link. Can you provide some suggestions or alternative methods to make the camera display smoother?
