I have created a new widget with several images. I would like to use the function lv_obj_add_style() to set them style. Only one part should be set all image styles. Currently, I use the functions lv_obj_get_style_**() to get each parameter, then I set them with lv_obj_set_style_local_**().
I would like get a lv_style_list_t with lv_obj_get_style_list(), then set the style of all images with it.
7.3.1
#include "lvgl.h"
enum {
ADSP_LV_WIDGET_PART_BG = LV_CONT_PART_MAIN,
ADSP_LV_WIDGET_PART_IMAGES = _LV_CONT_PART_VIRTUAL_LAST,
ADSP__LV_WIDGET_PART_VIRTUAL_LAST,
ADSP__LV_WIDGET_PART_REAL_LAST = _LV_CONT_PART_REAL_LAST
typedef struct {
lv_cont_ext_t ContPage; /*Ext. of ancestor*/
lv_obj_t *Images[3];
lv_style_list_t ImageStyle;
} adspLvWidgetExt_ts;
static lv_style_list_t * adspLvWidgetGetStyle(lv_obj_t * apObj, uint8_t aPart)
adspLvSubMenuTitleExt_ts *wpExt;
lv_style_list_t * wpStyleDsc;
/* Get the extended memory of the widget */
wpExt = lv_obj_get_ext_attr(apObj);
switch(aPart)
case ADSP_LV_WIDGET_PART_BG:
wpStyleDsc = lv_obj_get_style_list(apObj, LV_CONT_PART_MAIN);
break;
case ADSP_LV_WIDGET_PART_IMAGES:
wpStyleDsc = &wpExt->ImageStyle;
break;
default:
wpStyleDsc = NULL;
return wpStyleDsc;
static lv_res_t adspLvWidgetSignal(lv_obj_t * apObj, lv_signal_t aSign, void * apParam)
lv_res_t wRes;
lv_color_t wImageRecolor;
lv_opa_t wImageRecolorOpa;
if(aSign == LV_SIGNAL_GET_STYLE)
/* Get the part style */
lv_get_style_info_t * wpInfo = apParam;
wpInfo->result = adspLvWidgetGetStyle(apObj, wpInfo->part);
if(wpInfo->result != NULL)
wRes = LV_RES_OK;
/* Get the ancestor style */
wRes = mAncestorSignal(apObj, aSign, apParam);
/* Include the ancient signal function */
if (wRes == LV_RES_OK)
if (aSign == LV_SIGNAL_STYLE_CHG)
/* Get the parameter style used */
wImageRecolor = lv_obj_get_style_image_recolor(apObj, ADSP_LV_WIDGET_PART_IMAGES);
wImageRecolorOpa = lv_obj_get_style_image_recolor_opa(apObj, ADSP_LV_WIDGET_PART_IMAGES);
// TODO : Replace the following lines by :
lv_style_list_t *wpListStyle = lv_obj_get_style_list(apObj, ADSP_LV_WIDGET_PART_IMAGES);
lv_obj_set_list_style(wpExt->Images[0], LV_IMG_PART_MAIN, wpListStyle );
lv_obj_set_list_style(wpExt->Images[1], LV_IMG_PART_MAIN, wpListStyle );
lv_obj_set_list_style(wpExt->Images[2], LV_IMG_PART_MAIN, wpListStyle );
/* Set for each image the style */
lv_obj_set_style_local_image_recolor(wpExt->Images[0], LV_IMG_PART_MAIN, LV_STATE_DEFAULT, wImageRecolor);
lv_obj_set_style_local_image_recolor_opa(wpExt->Images[0], LV_IMG_PART_MAIN, LV_STATE_DEFAULT, wImageRecolorOpa);
lv_obj_set_style_local_image_recolor(wpExt->Images[1], LV_IMG_PART_MAIN, LV_STATE_DEFAULT, wImageRecolor);
lv_obj_set_style_local_image_recolor_opa(wpExt->Images[1], LV_IMG_PART_MAIN, LV_STATE_DEFAULT, wImageRecolorOpa);
lv_obj_set_style_local_image_recolor(wpExt->Images[2], LV_IMG_PART_MAIN, LV_STATE_DEFAULT, wImageRecolor);
lv_obj_set_style_local_image_recolor_opa(wpExt->Images[2], LV_IMG_PART_MAIN, LV_STATE_DEFAULT, wImageRecolorOpa);
return wRes;
lv_obj_t * adspLvWigetCreate(lv_obj_t * apContParent)
lv_obj_t *wpMainCont;
lv_obj_t *wpObj;
/* Create the default container */
wpMainCont = lv_cont_create(apContParent, NULL);
/* Allocate the memory for this widget */
wpExt = lv_obj_allocate_ext_attr(wpMainCont, sizeof(adspLvWidgetExt_ts));
if(NULL == wpExt)
lv_obj_del(wpMainCont);
wpMainCont = NULL;
/* Get the ancestor signal callback */
if(NULL == mAncestorSignal)
mAncestorSignal = lv_obj_get_signal_cb(wpMainCont);
/* Set a signal callback */
lv_obj_set_signal_cb(wpMainCont, adspLvWidgetSignal);
/* Initialise the image style list */
lv_style_list_init(&wpExt->ImageStyle);
/* Common container */
lv_obj_set_size(wpMainCont, 200, 200);
lv_cont_set_layout(wpMainCont, LV_LAYOUT_ROW_TOP);
/* Images */
wpExt->Images[0] = lv_img_create(wpMainCont, NULL);
lv_img_set_src(wpExt->Images[0], &image1);
wpExt->Images[1] = lv_img_create(wpMainCont, NULL);
lv_img_set_src(wpExt->Images[1], &image2);
wpExt->Images[2] = lv_img_create(wpMainCont, NULL);
lv_img_set_src(wpExt->Images[2], &image3);
return wpMainCont;
