RXX
March 17, 2020, 10:00am
#1
I ran into a problem that I can’t make the roller higher, I want only one element to be visible in the roller, maybe I need to increase the font, but it didn’t work out for me (
PC Simulator
lv_roller_set_visible_row_count(roller1, 1);
this function is not quite what I need
Create style
with
style.text.font = &your_bigger_font;
And set it to LV_ROLLER_STYLE_BG
by the roller’a api lv_roller_set_style(…)
and after this step, add your options to your roller.
RXX
March 17, 2020, 11:52am
#3
black screen(
void roller(lv_obj_t *sb, int* x_pos, int* y_pos)
static lv_style_t style_btn_bg;
static lv_style_t style_btn_pr_bg;
lv_obj_t *roller1 = lv_roller_create(sb, NULL);
lv_roller_set_options(roller1,
"1\n"
"2\n"
"3\n"
"4\n"
"5\n"
"6\n"
"7\n"
"8\n"
"9\n"
"10\n"
"12\n"
"13\n"
"14\n"
"15\n"
"16\n"
"17\n"
"18\n"
"19\n"
"20\n"
"21\n"
"22\n"
"23\n"
"24",
LV_ROLLER_MODE_INIFINITE);
// style_btn_bg.body.main_color = LV_COLOR_DARK_YELLOW;
// style_btn_bg.body.grad_color = LV_COLOR_GRAY;
// style_btn_bg.text.color = LV_COLOR_WHITE;
style_btn_bg.text.font = LV_FONT_ROBOTO_22;
lv_style_copy(&style_btn_pr_bg, &style_btn_bg);
// style_btn_pr_bg.body.main_color = LV_COLOR_BUTTON_PR_GRAY;
// style_btn_pr_bg.body.grad_color = LV_COLOR_BUTTON_PR_GRAY;
lv_roller_set_style(roller1,LV_ROLLER_STYLE_BG, &style_btn_bg);
// lv_roller_set_style(roller1,LV_BTN_STYLE_PR, &style_btn_pr_bg);
lv_roller_set_fix_width(roller1, 60);
lv_obj_align(roller1, NULL, LV_ALIGN_CENTER, x_pos, y_pos);
lv_obj_set_event_cb(roller1, event_roller);
lv_roller_set_options(..)
must be called
after lv_roller_set_style(..)
RXX
March 17, 2020, 12:31pm
#6
ok i fixed but font size doesn’t change
does not work with function
LV_ROLLER_STYLE_BG
work with function LV_ROLLER_STYLE_SEL
you have idea?
I use the following code on dev7.0
void lv_ex_roller_1(void)
lv_obj_t *roller1 = lv_roller_create(lv_scr_act(), NULL);
static lv_style_t style_bg, style_select;
lv_style_copy(&style_bg, (lv_style_t*) lv_roller_get_style(roller1, LV_ROLLER_STYLE_BG));
lv_style_copy(&style_select,(lv_style_t*) lv_roller_get_style(roller1, LV_ROLLER_STYLE_SEL));
lv_roller_set_style(roller1, LV_ROLLER_STYLE_BG, &style_bg);
lv_roller_set_style(roller1, LV_ROLLER_STYLE_SEL, &style_select);
style_bg.text.font = &YOUR_FONT; // change font
style_select.body.main_color = LV_COLOR_RED;
style_select.body.grad_color = LV_COLOR_RED;
"January\n"
"February\n"
"March\n"
"April\n"
"May\n"
"June\n"
"July\n"
"August\n"
"September\n"
"October\n"
"November\n"
"December",
lv_obj_align(roller1, NULL, LV_ALIGN_CENTER, 0, 0);
When change 2 different fonts , the results are…
First : smaller_font
Second : bigger_font
RXX
March 17, 2020, 12:55pm
#8
TridentTD:
lv_obj_t roller1 = lv_roller_create(lv_scr_act(), NULL); static lv_style_t style_bg, style_select; lv_style_copy(&style_bg, (lv_style_t ) lv_roller_get_style(roller1, LV_ROLLER_STYLE_BG)); lv_style_copy(&style_select,(lv_style_t*) lv_roller_get_style(roller1, LV_ROLLER_STYLE_SEL)); lv_roller_set_style(roller1, LV_ROLLER_STYLE_BG, &style_bg); lv_roller_set_style(roller1, LV_ROLLER_STYLE_SEL, &style_select); style_bg.text.font = &YOUR_FONT; // change font style_select.body.main_color = LV_COLOR_RED; style_select.body.grad_color = LV_COLOR_RED;
it`s working, Thanks so much)))
RXX
March 17, 2020, 1:07pm
#9
Well, another question, how to fix it, roller is hiding behind the button and other items
I don’t get the point of your last issue.
Can you give more information ?
RXX
March 17, 2020, 1:23pm
#11
I apologize for my English, I showed a screenshot with a problem where a cover roller is hiding behind a button or behind any other object
my roller has two states, closed as a roller on the left and open as a roller on the right
when you click on a closed clip, it opens, but after opening it hides behind other objects, which do not look very visual
I’m not sure about your point of the issue.
Learn more about align .
and order of the object for alignment.
RXX
March 17, 2020, 1:33pm
#13
look at the screenshot and tell me what’s wrong with it)
RXX
March 17, 2020, 1:37pm
#14
I think I understand what the problem is
again, thancks so much)
Objects derive their z-index from the order in which they were attached to their parent. Take a look at the documentation .
RXX
March 17, 2020, 2:28pm
#17
Another question is how to make the roller display not down (as a list), but in the middledemo.zip (165.2 KB)
Are you trying to align it with the colon?
RXX
March 18, 2020, 10:42am
#19
no, i want, so that, roller when you press not down drop, and in the middel
Can you get a video of the current behavior? I’m having trouble understanding what you mean.
