https://lvgl.github.io/lv_examples/lv_ex_btnmatrix_1/index.html
I am running the lv_ex_btnmatrix_1 example with Arduino.(compiled with the Arduino IDE)
The example creates a keypad. When a button is pressed the button value (txt) is printed.
How do I get the value of the button (in txt) accessible in my code?
I assume that I could copy txt to a global variable, but I always get an error.
What MCU/Processor/Board and compiler are you using? ESP32
What LVGL version are you using? 7
What do you want to achieve? Make the value of txt available to my code in the loop().
keyValue = txt;
#include "../../../lv_examples.h"
#include <stdio.h>
#if LV_USE_BTNMATRIX
if(event == LV_EVENT_VALUE_CHANGED) {
const char * txt = lv_btnmatrix_get_active_btn_text(obj);
printf("%s was pressed\n", txt);
static const char * btnm_map[] = {"1", "2", "3", "4", "5", "\n",
"6", "7", "8", "9", "0", "\n",
"Action1", "Action2", ""};
void lv_ex_btnmatrix_1(void)
lv_obj_t * btnm1 = lv_btnmatrix_create(lv_scr_act(), NULL);
lv_btnmatrix_set_map(btnm1, btnm_map);
lv_btnmatrix_set_btn_width(btnm1, 10, 2); /*Make "Action1" twice as wide as "Action2"*/
lv_btnmatrix_set_btn_ctrl(btnm1, 10, LV_BTNMATRIX_CTRL_CHECKABLE);
lv_btnmatrix_set_btn_ctrl(btnm1, 11, LV_BTNMATRIX_CTRL_CHECK_STATE);
lv_obj_align(btnm1, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_event_cb(btnm1, event_handler);
