I also did want to mention that I set it up to statically link the library so you won’t have to worry about moving the compiled micropython binary or the location of a shared library at all. It will be compiled right into the micropython binary.
Yea, that’s cool, thanks for the help/suggestion.
It really didn’t cross my mind that the lib might be outdated, the pycparser thing is still too new for me, so I thought it had more to do with the makefile, than the lib.
I am still getting issues with building using the makefile, which I’ve adjusted a bit:
# libjpeg-turbo build rules
MOD_DIR := $(abspath $(USERMOD_DIR))
LIB_JPEG = $(MOD_DIR)/libjpeg-turbo
LIB_JPEG_SOURCE = $(abspath $(BUILD))/libjpeg-turbo
LIB_JPEG_BUILD = $(LIB_JPEG_SOURCE)/build
LVGL_BINDING_DIR = $(abspath $(TOP))/lib/lv_bindings
LIB_JPEG_PP = $(abspath $(BUILD))/libjpeg-turbo/libjpeg_turbo.pp.c
LIB_JPEG_MPY = $(abspath $(BUILD))/libjpeg-turbo/libjpeg_turbo_mpy.c
LIB_JPEG_MPY_METADATA = $(abspath $(BUILD))/libjpeg-turbo/libjpeg_turbo_mpy.json
CFLAGS_USERMOD += -Wno-unused-function
CFLAGS_USERMOD += -Wno-missing-field-initializers
CFLAGS_USERMOD += -I$(LIB_JPEG_BUILD)
CFLAGS_USERMOD += -I$(LIB_JPEG)
SRC_USERMOD_C += $(LIB_JPEG_MPY)
LDFLAGS_USERMOD += -L$(LIB_JPEG_BUILD)
LDFLAGS_USERMOD += -l:libjpeg.a
# Use the full path for the JPEG header
JPEG_HEADER = $(LIB_JPEG)/jpeglib.h
$(JPEG_HEADER):
$(ECHO) "LIB_JPEG-BUILD $@"
$(Q)cd $(MOD_DIR)
$(Q)[ -d libjpeg-turbo ] || git clone https://github.com/libjpeg-turbo/libjpeg-turbo
$(Q)mkdir -p $(LIB_JPEG_BUILD)
$(Q)cd $(LIB_JPEG_BUILD)
$(Q)cmake -G "Unix Makefiles" -DENABLE_SHARED=FALSE -DENABLE_STATIC=TRUE -DCMAKE_BUILD_TYPE=Release $(LIB_JPEG_SOURCE)
$(Q)make
.PHONY: JPEG_HEADER
JPEG_HEADER: $(JPEG_HEADER)
$(LIB_JPEG_PP): $(JPEG_HEADER)
$(ECHO) "LIB_JPEG-PP $@"
$(Q)mkdir -p $(dir $@)
$(Q)$(CPP) $(LIB_JPEG_CFLAGS) -DPYCPARSER -x c -I $(LVGL_BINDING_DIR)/pycparser/utils/fake_libc_include $(JPEG_HEADER) > $(LIB_JPEG_PP)
.PHONY: LIB_JPEG_PP
LIB_JPEG_PP: $(LIB_JPEG_PP)
$(LIB_JPEG_MPY): $(LVGL_BINDING_DIR)/gen/gen_mpy.py $(LIB_JPEG_PP)
$(ECHO) "LIB_JPEG-MPY $@"
$(Q)$(PYTHON) $(LVGL_BINDING_DIR)/gen/gen_mpy.py -M jpeg -MP jpeg -MD $(LIB_JPEG_MPY_METADATA) -E $(LIB_JPEG_PP) $(JPEG_HEADER) > $@
.PHONY: LIB_JPEG_MPY
LIB_JPEG_MPY: $(LIB_JPEG_MPY)
Output:
$ make -j4 -C ports/unix USER_C_MODULES="$(pwd)/custom_mod/libjpeg_turbo" V=1
make: Entering directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix'
Including User C Module from /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo
LIB_JPEG-BUILD /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/libjpeg-turbo/jpeglib.h
cd /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo
python3 ../../py/makeversionhdr.py build-standard/genhdr/mpversion.h
mkdir -p /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo/build
cd /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo/build
cmake -G "Unix Makefiles" -DENABLE_SHARED=FALSE -DENABLE_STATIC=TRUE -DCMAKE_BUILD_TYPE=Release /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo
CMake Warning:
Ignoring extra path from command line:
"/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo"
CMake Error: The source directory "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
make: *** [/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/micropython.mk:35: /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/libjpeg-turbo/jpeglib.h] Error 1
make: Leaving directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix'
The confusing part is the fact that THERE IS a CMakeLists.txt right inside the directory, clearly there to be built.
The reason I’ve changed your suggestion is since I got this error before:
cmake -G "Unix Makefiles" -DENABLE_SHARED=FALSE -DENABLE_STATIC=TRUE -DCMAKE_BUILD_TYPE=Release /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/libjpeg-turbo
CMake Error: The source directory "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/libjpeg-turbo" does not exist.
So I figured, that it is trying to build the source from the wrong directory.
I have created this structure:
And I am building with:
For a bit more context
I only really jumped back into this, because having copied the JPEG code from github, I am still getting screenshot results that are distorted.
As an example:
The reason why they are distorted is beyond me and I thought I’ll experiment trying out your suggestion to possibly fix it.
It might not even solve the issue, since it could also be a race condition of LVGL updating the window while I take a snapshot.
Here’s the snapshot code for a bit more context:
def bgr_to_rgb(data):
"""Swap the BGR values to RGB in a flat bytearray."""
# Assume data is a flat bytearray in BGR format
for i in range(0, len(data), 3):
data[i], data[i+2] = data[i+2], data[i] # Swap the B and R values
return data
def take_screenshot(container: lv.obj, output_file: str, quality:int = 100):
"""Take a screenshot of a container using the LVGL snapshot API and save it to a JPG file."""
container.update_layout() # Added this here to enforce an update/rerender of screen?
snapshot = lv.snapshot_take(container, lv.COLOR_FORMAT.NATIVE)
print(f"Snapshot: {snapshot} ({type(snapshot)}, {snapshot.data_size} bytes)")
data_size = snapshot.data_size
buffer = snapshot.data.__dereference__(data_size)
container.update_layout() # again here to really make sure we have a finished update/render before serializing?
img = image(container.get_width(), container.get_height(), "rgb", bgr_to_rgb(buffer))
try:
with open(output_file, 'wb') as f:
f.write(serialize(img, quality))
except MemoryError as e:
print(e)
finally:
snapshot.destroy()
The serialize function is from here: flat/flat/jpeg.py at 43bae3d8183bc8b5b44f089ead70b6a9366da0a2 · xxyxyz/flat · GitHub
Maybe using libjpeg won’t solve this issue at all however.
In regard to what I’m targeting:
I am only ever going to build this using the Unix port. The generator is only supposed to run there, since I’m only synthesizing user interfaces for creating datasets of LVGL UIs.
It’s working out well so far, check full source here:
The makefile was an example. It was not tested. It was to point you in the right direction. Try this instead and paste the output to me so I can see what is going on.
LIB_JPEG_BUILD = $(MOD_DIR)/libjpeg-turbo/build
$(JPEG_HEADER):
cd $(MOD_DIR)
cmake -G"Unix Makefiles" -DENABLE_SHARED=FALSE -DENABLE_STATIC=TRUE -DCMAKE_BUILD_TYPE=Release ..
make
.PHONY: JPEG_HEADER
mkdir -p $(dir $@)
.PHONY: LIB_JPEG_PP
mkdir -p /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/libjpeg-turbo/build
cd /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/libjpeg-turbo/build
cmake -G"Unix Makefiles" -DENABLE_SHARED=FALSE -DENABLE_STATIC=TRUE -DCMAKE_BUILD_TYPE=Release -S ./libjpeg-turbo
-- The C compiler identification is GNU 12.2.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- CMAKE_BUILD_TYPE = Release
-- VERSION = 3.0.3, BUILD = 20240516
-- 64-bit build (x86_64)
-- CMAKE_INSTALL_PREFIX = /opt/libjpeg-turbo
-- CMAKE_INSTALL_BINDIR = bin (/opt/libjpeg-turbo/bin)
-- CMAKE_INSTALL_DATAROOTDIR = (/opt/libjpeg-turbo)
-- CMAKE_INSTALL_DOCDIR = doc (/opt/libjpeg-turbo/doc)
-- CMAKE_INSTALL_INCLUDEDIR = include (/opt/libjpeg-turbo/include)
-- CMAKE_INSTALL_LIBDIR = lib64 (/opt/libjpeg-turbo/lib64)
-- CMAKE_INSTALL_MANDIR = man (/opt/libjpeg-turbo/man)
-- Shared libraries disabled (ENABLE_SHARED = 0)
-- Static libraries enabled (ENABLE_STATIC = 1)
-- Arithmetic decoding support enabled (WITH_ARITH_DEC = 1)
-- Arithmetic encoding support enabled (WITH_ARITH_ENC = 1)
-- TurboJPEG API library enabled (WITH_TURBOJPEG = 1)
-- TurboJPEG Java wrapper disabled (WITH_JAVA = 0)
-- Emulating libjpeg API/ABI v6.2 (WITH_JPEG7 = 0, WITH_JPEG8 = 0)
-- libjpeg API shared library version = 62.4.0
-- Compiler flags = -O3 -DNDEBUG
-- Linker flags =
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of size_t
-- Check size of size_t - done
-- Check size of unsigned long
-- Check size of unsigned long - done
-- Performing Test HAVE_BUILTIN_CTZL
-- Performing Test HAVE_BUILTIN_CTZL - Success
-- Performing Test RIGHT_SHIFT_IS_UNSIGNED
-- Performing Test RIGHT_SHIFT_IS_UNSIGNED - Failed
-- Performing Test HIDDEN_WORKS
-- Performing Test HIDDEN_WORKS - Success
-- HIDDEN = __attribute__((visibility("hidden")))
-- Performing Test INLINE_WORKS
-- Performing Test INLINE_WORKS - Success
-- INLINE = __inline__ __attribute__((always_inline)) (FORCE_INLINE = 1)
-- Performing Test HAVE_THREAD_LOCAL
-- Performing Test HAVE_THREAD_LOCAL - Success
-- THREAD_LOCAL = __thread
-- Performing Test HAVE_VERSION_SCRIPT
-- Performing Test HAVE_VERSION_SCRIPT - Success
-- Linker supports GNU-style version scripts
-- CMAKE_EXECUTABLE_SUFFIX =
-- Looking for a ASM_NASM compiler
-- Looking for a ASM_NASM compiler - NOTFOUND
CMake Warning at simd/CMakeLists.txt:5 (message):
SIMD extensions disabled: could not find NASM compiler. Performance will
suffer.
Call Stack (most recent call first):
simd/CMakeLists.txt:48 (simd_fail)
-- FLOATTEST8 = no-fp-contract
-- FLOATTEST12 = no-fp-contract
-- RPM architecture = x86_64, DEB architecture = amd64
-- Configuring done
-- Generating done
-- Build files have been written to: /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix
make
make[1]: Entering directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix'
make[1]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule.
make[2]: Entering directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix'
make[3]: Entering directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix'
make[3]: Leaving directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix'
[ 1%] Building C object CMakeFiles/jpeg12-static.dir/jcapistd.c.o
... output too long ...
[100%] Built target md5cmp
make[2]: Leaving directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix'
make[1]: Leaving directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix'
LIB_JPEG-PP /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo/libjpeg_turbo.pp.c
gcc -E -DPYCPARSER -x c -I ../../lib/lv_bindings/pycparser/utils/fake_libc_include /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/libjpeg-turbo/jpeglib.h > /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo/libjpeg_turbo.pp.c
cc1: fatal error: /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/libjpeg-turbo/jpeglib.h: No such file or directory
compilation terminated.
make: *** [/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/micropython.mk:45: /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo/libjpeg_turbo.pp.c] Error 1
make: *** Deleting file '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/build-standard/libjpeg-turbo/libjpeg_turbo.pp.c'
easy fix…
too many libjpeg-turbo directories in the path for the header file.
check to see if this file exists.
Lets change this…
lv_micropython/custom_mod/libjpeg_turbo/micropython.mk
make -j4 -C ports/unix USER_C_MODULES="$(pwd)/custom_mod/" V=1
get rid of that extra path for shits and giggles.
also in the preprocess rule remove the space that is in there for the include.
give this one a shot…
MOD_DIR := $(USERMOD_DIR)
LVGL_BINDING_DIR = $(TOP)/lib/lv_bindings
LIB_JPEG_PP = $(BUILD)/libjpeg-turbo/libjpeg_turbo.pp
LIB_JPEG_MPY = $(BUILD)/libjpeg-turbo/libjpeg_turbo_mpy.c
LIB_JPEG_MPY_METADATA = $(BUILD)/libjpeg-turbo/libjpeg_turbo.json
$(JPEG_HEADER):
cd $(MOD_DIR)
make
.PHONY: JPEG_HEADER
mkdir -p $(dir $@)
$(CPP) $(LIB_JPEG_CFLAGS) $(CFLAGS_USERMOD) -DPYCPARSER -x c -I$(LVGL_BINDING_DIR)/pycparser/utils/fake_libc_include $(JPEG_HEADER) > $(LIB_JPEG_PP)
.PHONY: LIB_JPEG_PP
Made the suggested folder changes.
Currently:
That one seemed to work.
$ make -j4 -C ports/unix USER_C_MODULES="$(pwd)/custom_mod" V=1
[ 1%] Built target turbojpeg12-static
[ 2%] Built target turbojpeg16-static
[ 8%] Built target jpeg16-static
[ 21%] Built target jpeg12-static
[ 22%] Built target cjpeg12-static
[ 23%] Built target cjpeg16-static
[ 24%] Built target rdjpgcom
[ 25%] Built target djpeg12-static
[ 26%] Built target djpeg16-static
[ 27%] Built target wrjpgcom
[ 28%] Built target strtest
[ 29%] Built target md5cmp
[ 55%] Built target jpeg-static
[ 85%] Built target turbojpeg-static
[ 88%] Built target cjpeg-static
[ 91%] Built target jpegtran-static
[ 96%] Built target djpeg-static
[ 96%] Built target example-static
[ 98%] Built target tjunittest-static
[100%] Built target tjbench-static
However, when running the micropython binary, I still can’t ìmport jpeg
take a look at the c code it generated…
Not exactly sure what to look for. It created those binaries as it said. I thought it’s going to link it to the micropython binary
in the build folder. attach the file to a post for me
I figured out the issue. The micropython.mk does not work, because every line in the makefile is on a seperate shell, so it actually never performed the steps where we want them too…
Here is my adjusted version:
$(JPEG_HEADER):
echo "Entering $(MOD_DIR)"; \
cd $(MOD_DIR); \
echo "Cloning libjpeg-turbo"; \
[ -d libjpeg-turbo ] || git clone https://github.com/libjpeg-turbo/libjpeg-turbo; \
echo "Creating build directory"; \
mkdir -p $(LIB_JPEG_BUILD); \
echo "Entering $(LIB_JPEG_BUILD)"; \
cd $(LIB_JPEG_BUILD); \
echo "Configuring libjpeg-turbo"; \
cmake -G"Unix Makefiles" -DENABLE_SHARED=FALSE -DENABLE_STATIC=TRUE -DCMAKE_BUILD_TYPE=Release ..; \
echo "Building libjpeg-turbo"; \
make
.PHONY: JPEG_HEADER
mkdir -p $(dir $@)
.PHONY: LIB_JPEG_PP
However, this again brings me back to the original problem:
LIB_JPEG-BUILD /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h
Entering /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo
/bin/sh: 4: @echo: Permission denied
Cloning into 'libjpeg-turbo'...
remote: Enumerating objects: 20311, done.
remote: Counting objects: 100% (1342/1342), done.
remote: Compressing objects: 100% (501/501), done.
remote: Total 20311 (delta 881), reused 1111 (delta 772), pack-reused 18969
Receiving objects: 100% (20311/20311), 17.86 MiB | 5.30 MiB/s, done.
Resolving deltas: 100% (14996/14996), done.
/bin/sh: 6: @echo: Permission denied
/bin/sh: 8: @echo: Permission denied
/bin/sh: 10: @echo: Permission denied
-- VERSION = 3.0.4, BUILD = 20240517
-- Linker flags =
suffer.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/build
/bin/sh: 12: @echo: Permission denied
make[1]: Entering directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/build'
make[2]: Entering directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/build'
make[3]: Entering directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/build'
make[3]: Leaving directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/build'
[ 13%] Built target jpeg12-static
[ 19%] Built target jpeg16-static
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jchuff.c: In function ‘jpeg_gen_optimal_table’:
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jchuff.c:1042:22: warning: writing 1 byte into a region of size 0 [-Wstringop-overflow=]
1042 | bits[codesize[i]]++;
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jchuff.c:945:9: note: at offset 33 into destination object ‘bits’ of size 33
945 | UINT8 bits[MAX_CLEN + 1]; /* bits[k] = # of symbols with code length k */
[ 45%] Linking C static library libjpeg.a
[ 45%] Built target jpeg-static
[ 45%] Building C object CMakeFiles/turbojpeg12-static.dir/rdppm.c.o
[ 46%] Building C object CMakeFiles/turbojpeg12-static.dir/wrppm.c.o
[ 46%] Built target turbojpeg12-static
[ 47%] Built target turbojpeg16-static
[ 77%] Linking C static library libturbojpeg.a
[ 77%] Built target turbojpeg-static
[ 77%] Building C object CMakeFiles/tjunittest-static.dir/tjunittest.c.o
[ 77%] Building C object CMakeFiles/tjunittest-static.dir/tjutil.c.o
[ 78%] Building C object CMakeFiles/tjunittest-static.dir/md5/md5.c.o
[ 78%] Building C object CMakeFiles/tjunittest-static.dir/md5/md5hl.c.o
[ 79%] Linking C executable tjunittest-static
[ 79%] Built target tjunittest-static
[ 80%] Building C object CMakeFiles/tjbench-static.dir/tjbench.c.o
[ 80%] Building C object CMakeFiles/tjbench-static.dir/tjutil.c.o
[ 81%] Linking C executable tjbench-static
[ 81%] Built target tjbench-static
[ 82%] Building C object CMakeFiles/cjpeg12-static.dir/rdgif.c.o
[ 82%] Building C object CMakeFiles/cjpeg12-static.dir/rdppm.c.o
[ 82%] Built target cjpeg12-static
[ 82%] Building C object CMakeFiles/cjpeg16-static.dir/rdgif.c.o
[ 83%] Building C object CMakeFiles/cjpeg16-static.dir/rdppm.c.o
[ 83%] Built target cjpeg16-static
[ 83%] Building C object CMakeFiles/cjpeg-static.dir/cjpeg.c.o
[ 83%] Building C object CMakeFiles/cjpeg-static.dir/cdjpeg.c.o
[ 84%] Building C object CMakeFiles/cjpeg-static.dir/rdbmp.c.o
[ 84%] Building C object CMakeFiles/cjpeg-static.dir/rdgif.c.o
[ 85%] Building C object CMakeFiles/cjpeg-static.dir/rdppm.c.o
[ 85%] Building C object CMakeFiles/cjpeg-static.dir/rdswitch.c.o
[ 86%] Building C object CMakeFiles/cjpeg-static.dir/rdtarga.c.o
[ 86%] Linking C executable cjpeg-static
[ 86%] Built target cjpeg-static
[ 86%] Building C object CMakeFiles/djpeg12-static.dir/rdcolmap.c.o
[ 87%] Building C object CMakeFiles/djpeg12-static.dir/wrgif.c.o
[ 87%] Building C object CMakeFiles/djpeg12-static.dir/wrppm.c.o
[ 87%] Built target djpeg12-static
[ 88%] Building C object CMakeFiles/djpeg16-static.dir/wrppm.c.o
[ 88%] Built target djpeg16-static
[ 88%] Building C object CMakeFiles/djpeg-static.dir/djpeg.c.o
[ 89%] Building C object CMakeFiles/djpeg-static.dir/cdjpeg.c.o
[ 89%] Building C object CMakeFiles/djpeg-static.dir/rdcolmap.c.o
[ 90%] Building C object CMakeFiles/djpeg-static.dir/rdswitch.c.o
[ 90%] Building C object CMakeFiles/djpeg-static.dir/wrbmp.c.o
[ 91%] Building C object CMakeFiles/djpeg-static.dir/wrgif.c.o
[ 91%] Building C object CMakeFiles/djpeg-static.dir/wrppm.c.o
[ 91%] Building C object CMakeFiles/djpeg-static.dir/wrtarga.c.o
[ 92%] Linking C executable djpeg-static
[ 92%] Built target djpeg-static
[ 93%] Building C object CMakeFiles/jpegtran-static.dir/jpegtran.c.o
[ 93%] Building C object CMakeFiles/jpegtran-static.dir/cdjpeg.c.o
[ 94%] Building C object CMakeFiles/jpegtran-static.dir/rdswitch.c.o
[ 94%] Building C object CMakeFiles/jpegtran-static.dir/transupp.c.o
[ 95%] Linking C executable jpegtran-static
[ 95%] Built target jpegtran-static
[ 95%] Building C object CMakeFiles/example-static.dir/example.c.o
[ 96%] Linking C executable example-static
[ 97%] Building C object CMakeFiles/rdjpgcom.dir/rdjpgcom.c.o
[ 97%] Linking C executable rdjpgcom
[ 97%] Built target rdjpgcom
[ 97%] Building C object CMakeFiles/wrjpgcom.dir/wrjpgcom.c.o
[ 98%] Linking C executable wrjpgcom
[ 98%] Built target wrjpgcom
[ 99%] Building C object CMakeFiles/strtest.dir/strtest.c.o
[ 99%] Linking C executable strtest
[ 99%] Built target strtest
[ 99%] Building C object md5/CMakeFiles/md5cmp.dir/md5cmp.c.o
[ 99%] Building C object md5/CMakeFiles/md5cmp.dir/md5.c.o
[100%] Building C object md5/CMakeFiles/md5cmp.dir/md5hl.c.o
[100%] Linking C executable md5cmp
make[2]: Leaving directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/build'
make[1]: Leaving directory '/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/build'
LIB_JPEG-PP build-standard/libjpeg-turbo/libjpeg_turbo.pp
LIB_JPEG-MPY build-standard/libjpeg-turbo/libjpeg_turbo_mpy.c
File "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/ports/unix/../../lib/lv_bindings/gen/gen_mpy.py", line 294, in <module>
ast = parser.parse(s, filename='<none>')
File "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/lib/lv_bindings/gen/../pycparser/pycparser/c_parser.py", line 147, in parse
return self.cparser.parse(
File "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/lib/lv_bindings/gen/../pycparser/pycparser/ply/yacc.py", line 331, in parse
return self.parseopt_notrack(input, lexer, debug, tracking, tokenfunc)
File "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/lib/lv_bindings/gen/../pycparser/pycparser/ply/yacc.py", line 1199, in parseopt_notrack
tok = call_errorfunc(self.errorfunc, errtoken, self)
File "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/lib/lv_bindings/gen/../pycparser/pycparser/ply/yacc.py", line 193, in call_errorfunc
r = errorfunc(token)
File "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/lib/lv_bindings/gen/../pycparser/pycparser/c_parser.py", line 1931, in p_error
self._parse_error(
File "/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/lib/lv_bindings/gen/../pycparser/pycparser/plyparser.py", line 67, in _parse_error
raise ParseError("%s: %s" % (coord, msg))
pycparser.plyparser.ParseError: /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:841:3: before: size_t
make: *** [/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/micropython.mk:58: build-standard/libjpeg-turbo/libjpeg_turbo_mpy.c] Error 1
make: *** Deleting file 'build-standard/libjpeg-turbo/libjpeg_turbo_mpy.c'
I’ve cut only a few [Build] object xyz ... messages, due to the input limit in the forum.
Notably, pycparser.plyparser.ParseError: /home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:841:3: before: size_t is still the culprit.
I have no idea why, but I tried running the command for the .pp output manually:
gcc -nostdinc -Wno-unused-function -Wno-missing-field-initializers -I$(pwd)/custom_mod/libjpeg_turbo/libjpeg-turbo/build -I$(pwd)/custom_mod/libjpeg_turbo/libjpeg-turbo -DPYCPARSER -x c -I$(pwd)lib/lv_bindings/pycparser/utils/fake_libc_include $(pwd)/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h > $(pwd)/ports/unix/build-standard/libjpeg-turbo/libjpeg_turbo.pp
And it produced errors:
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:841:3: error: unknown type name ‘size_t’
841 | size_t free_in_buffer; /* # of byte spaces remaining in buffer */
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:853:3: error: unknown type name ‘size_t’
853 | size_t bytes_in_buffer; /* # of bytes remaining in buffer */
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:884:58: error: unknown type name ‘size_t’
884 | void *(*alloc_small) (j_common_ptr cinfo, int pool_id, size_t sizeofobject);
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:35:1: note: ‘size_t’ is defined in header ‘<stddef.h>’; did you forget to ‘#include <stddef.h>’?
34 | #include "jmorecfg.h" /* seldom changed options */
+++ |+#include <stddef.h>
35 |
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:886:25: error: unknown type name ‘size_t’
886 | size_t sizeofobject);
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:886:25: note: ‘size_t’ is defined in header ‘<stddef.h>’; did you forget to ‘#include <stddef.h>’?
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:961:34: error: unknown type name ‘size_t’
961 | size_t structsize);
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:961:34: note: ‘size_t’ is defined in header ‘<stddef.h>’; did you forget to ‘#include <stddef.h>’?
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:963:36: error: unknown type name ‘size_t’
963 | size_t structsize);
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:963:36: note: ‘size_t’ is defined in header ‘<stddef.h>’; did you forget to ‘#include <stddef.h>’?
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:970:52: error: unknown type name ‘FILE’
970 | EXTERN(void) jpeg_stdio_dest(j_compress_ptr cinfo, FILE *outfile);
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:35:1: note: ‘FILE’ is defined in header ‘<stdio.h>’; did you forget to ‘#include <stdio.h>’?
+++ |+#include <stdio.h>
35 |
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:971:53: error: unknown type name ‘FILE’
971 | EXTERN(void) jpeg_stdio_src(j_decompress_ptr cinfo, FILE *infile);
/home/rini-debian/git-stash/lvgl-ui-detector/lvgl_ui_generator_v2/lv_micropython/custom_mod/libjpeg_turbo/libjpeg-turbo/jpeglib.h:971:53: note: ‘FILE’ is defined in header ‘<stdio.h>’; did you forget to ‘#include <stdio.h>’?
And then I tried the other way again: make -j4 -C ports/unix USER_C_MODULES="$(pwd)/custom_mod" V=1
And it suddenly worked?
GEN build-standard/genhdr/qstr.i.last
GEN build-standard/genhdr/qstr.split
GEN build-standard/genhdr/moduledefs.split
GEN build-standard/genhdr/root_pointers.split
GEN build-standard/genhdr/compressed.split
GEN build-standard/genhdr/moduledefs.collected
GEN build-standard/genhdr/qstrdefs.collected.h
GEN build-standard/genhdr/compressed.collected
Module registrations updated
GEN build-standard/genhdr/root_pointers.collected
QSTR updated
GEN build-standard/genhdr/moduledefs.h
Root pointer registrations updated
GEN build-standard/genhdr/qstrdefs.generated.h
Compressed data updated
GEN build-standard/genhdr/root_pointers.h
GEN build-standard/genhdr/compressed.data.h
CC build-standard/libjpeg-turbo/libjpeg_turbo_mpy.c
CC ../../py/mpstate.c
LINK build-standard/micropython
text data bss dec hex filename
1758546 228880 7472 1994898 1e7092 build-standard/micropython
$ ./ports/unix/build-standard/micropython
MicroPython v1.20.0-713-g30dcb7019-dirty on 2024-05-17; linux [GCC 12.2.0] version
Use Ctrl-D to exit, Ctrl-E for paste mode
>>> import jpeg
>>> # SUCCESS
No idea why that made a difference…
Since you asked before, attached are the requested files.
libjpeg_turbo_mpy.c (37.4 KB)
Doesn’t seem to work yet though…
>>> dir(jpeg)
['__class__', '__name__', '__dict__', '_nesting', 'C_Pointer', '_lv_mp_int_wrapper']
