Hiding sign in spinbox widget
Is it possible to not show positive/negative sign in spinbox widget?
I’ve solved by modify lvgl code, It’s my need but I don’t know if is a good solution for everyone
STM32F103RC / Keil
hide sign in spinbox
modified original code in lv_spinbox.c
static void lv_spinbox_updatevalue(lv_obj_t* spinbox)
    lv_spinbox_ext_t* ext = lv_obj_get_ext_attr(spinbox);
    char buf[LV_SPINBOX_MAX_DIGIT_COUNT + 8];
    memset(buf, 0, sizeof(buf));
    char* buf_p = buf;
    int i;
    if (ext->range_min < 0) { // sign is hide if there are only positive values
        /*Add the sign*/
        (*buf_p) = ext->value >= 0 ? '+' : '-';
        buf_p++;
        /*padding left*/
        for (i = 0; i < ext->digit_padding_left; i++) {
            (*buf_p) = ' ';
            buf_p++;
    char digits[64];
Please fill the template to provide enough information to investigate your issue.
> ## Important: posts that do not use this template will be ignored or closed.
> ## Before posting
> - Get familiar with [Markdown](https://forum.lvgl.io/t/get-familiar-with-markdown/403) to format and structure your post
> - Be sure to update [lvgl](https://github.com/littlevgl/lvgl) from the latest version from the `master` branch.
> - Be sure you have checked the relevant part of the [documentation](https://docs.littlevgl.com/en/html/index.html). **We will not respond in detail to posts where you haven't read the relevant documentation.**
> - If applicable use the [Simulator](https://docs.littlevgl.com/en/html/get-started/pc-simulator.html) to eliminate hardware related issues.
>  *Delete this section if you read and applied the mentioned points.*
## Description
###  What MCU/Processor/Board and compiler are you using?
###  What do you want to achieve?
### What have you tried so far?
## Code to reproduce
```c
Sorry, I’ve update my post.
Thanks
It looks like a reasonable update!
Can you send a PR?
sorry I don’t know how to do :thinking:
Take a look at this article:
Ok i’ll do . Thanks
