Hide all objects - What is the easiest way?
I have many objects created like this…
lv_obj_t * slider = lv_slider_create(lv_scr_act(), NULL);
and i wish to hide ALL of the objects created with something like…
lv_obj_set_hidden(slider, true);
Is there a simple way i can do this for all of my objects rather than just one at a time?
Thanks!!!
Hi @flossandmeditate,
I would create your sliders as an array of pointers…
lv_obj_t * slider[NO_SLIDERS];
for( i=0; i<NO_SLIDERS; i++ ) {
    slider[i] = lv_slider_create(lv_scr_act(), NULL);
    lv_obj_set_hidden(slider[i], true);
Also you could create an enum for the index to make it easier to track the individual sliders.
For Example:
enum slider_names {
    Sldr_Volume,
    Sldr_Bass,
    Sldr_Mix
Then reference the array using the enum as follows:
lv_obj_set_event_cb(slider[Sldr_Volume], volume_handler);
Hope that helps.
Kind Regards,
Pete
what is [NO_SLIDERS]
can you please tell me?
Array or it is simple total no of all enums .
lv_obj_add_flag(lv_obj_t * obj, lv_obj_flag_t f);
lv_obj_t * obj ______________ here i have for example ui_Panel11 and i have 20 Panels so i want a loop that will do something like.
for (i=0;i<21;i++)
lv_obj_add_flag(ui_Panel, LV_OBJ_FLAG_HIDDEN));
hide one and unhide all others.
i see it is pointer (lv_obj_t *) strcut but i dont know how i can do this alternative instead of writing 20 lines with lot of ifs.
lv_obj_add_flag(“”“”“”““her i want something to loop for 20 Panels)””“”“”“”", LV_OBJ_FLAG_HIDDEN));
Hey you reply to 2020 message…
If you have answer!
all you have to do is hide the parent object. In this case the parent object is the screen.
lv_obj_t *screen = lv_screen_active();
lv_obj_add_flag(screen, LV_OBJ_FLAG_HIDDEN));
lv_obj_t *new_screen = lv_obj_create(NULL);
lv_load_screen(new_screen);
the new screen you can add UI elements to if you want.
another way is to iterate over the children in a screen and hide them
uint32_t child_count = lv_obj_get_child_count(screen);
for(uint32_t i=0;i<child_count;i++) {
    lv_obj_add_flag(lv_obj_get_child(screen, i), LV_OBJ_FLAG_HIDDEN);
either one of those would work.
and if you want to explicitly set the hidden flag on all UI elements you would use the following.
void recursive_hide(lv_obj_t *parent);
    uint32_t child_count = lv_obj_get_child_count(parent);
    lv_obj_t *child;
        child = lv_obj_get_child(parent, i);
        lv_obj_add_flag(child, LV_OBJ_FLAG_HIDDEN);
        recursive_hide(child);
recursive_hide(screen);
I have input like int 20 ,
so i have already created Panels1 to Panels 20.
It means if i enter 10 it will hide 10 Panels if i enter 20 it will hide 20 elements.
I want to hide in loop
lv_obj_add_flag(Panels1 to Panels20, LV_OBJ_FLAG_HIDDEN));
uint32_t i;
for(i = 0; i < lv_obj_get_child_count(parent); i++) {
lv_obj_t * child = lv_obj_get_child(parent, i);
/Do something with child/
Here is the same idea, thank you for hinting me. Thanks
The store the panels in an array and iterate over that array…
lv_obj_t *panels[20];
// create your panels and store them in the array
lv_obj_t *panel = lv_obj_create(lv_screen_active());
panels[0] = panel;
// rest of code to add to the panel and to create other panels goes here.
for(uint8_t i=0;i<20;i++) {
    lv_obj_add_flag(panels[i], LV_OBJ_FLAG_HIDDEN);
Thanks man for your answer .
no worries m8, Hopefully it helped you out.
If one of the responses I gave was the solution please mark that response as the solution so others will know there is a solution that was found.
Based on thread subject valid response is dont waste MCU cycles and simply switch to empty screen.
And only autor can mark valod response.
