Help converting this V8 code to V7
Hi, I have been struggling for 2 days now trying to convert the following V8 code to V7, and I gave up. Basically this is a system info UI, that scrolls and shows different values, It’s from an open source project that uses LVLG.
Simulator
V7
Convert this V8 snippet with animation to V7
I tried to create page, converted most of the styles, but just could’nt get the scrolling behavior
V8 code that I wish to convert to V7
#define ITEM_HEIGHT_MIN   100
#define ITEM_PAD          ((LV_VER_RES - ITEM_HEIGHT_MIN) / 2)
void SystemInfosView::Create(lv_obj_t* root)
    lv_obj_remove_style_all(root);
    lv_obj_set_size(root, LV_HOR_RES, LV_VER_RES);
    lv_obj_set_style_bg_color(root, lv_color_black(), 0);
    lv_obj_set_style_bg_opa(root, LV_OPA_COVER, 0);
    lv_obj_set_style_pad_ver(root, ITEM_PAD, 0);
    lv_obj_set_flex_flow(root, LV_FLEX_FLOW_COLUMN);
    lv_obj_set_flex_align(
        root,
        LV_FLEX_ALIGN_START,
        LV_FLEX_ALIGN_CENTER
    Style_Init();
    /* Item Sport */
    Item_Create(
        &ui.sport,
        root,
        "Sport",
        "bicycle",
        "Total trip\n"
        "Total time\n"
        "Max speed"
    /* Item GPS */
    Item_Create(
        &ui.gps,
        root,
        "GPS",
        "map_location",
        "Latitude\n"
        "Longitude\n"
        "Altitude\n"
        "UTC Time\n\n"
        "Course\n"
        "Speed"
    /* Item MAG */
    Item_Create(
        &ui.mag,
        root,
        "MAG",
        "compass",
        "Compass\n"
        "X\n"
        "Y\n"
        "Z"
    /* Item IMU */
    Item_Create(
        &ui.imu,
        root,
        "IMU",
        "gyroscope",
        "Step\n"
        "Ax\n"
        "Ay\n"
        "Az\n"
        "Gx\n"
        "Gy\n"
        "Gz"
    Group_Init();
void SystemInfosView::onFocus(lv_group_t* g)
    lv_obj_t* icon = lv_group_get_focused(g);
    lv_obj_t* cont = lv_obj_get_parent(icon);
    lv_coord_t y = lv_obj_get_y(cont);
    lv_obj_scroll_to_y(lv_obj_get_parent(cont), y, LV_ANIM_ON);
void SystemInfosView::Style_Init()
    lv_style_init(&style.icon);
    lv_style_set_width(&style.icon, 220);
    lv_style_set_bg_color(&style.icon, lv_color_black());
    lv_style_set_bg_opa(&style.icon, LV_OPA_COVER);
    lv_style_set_text_font(&style.icon, ResourcePool::GetFont("bahnschrift_17"));
    lv_style_set_text_color(&style.icon, lv_color_white());
    lv_style_init(&style.focus);
    lv_style_set_width(&style.focus, 70);
    lv_style_set_border_side(&style.focus, LV_BORDER_SIDE_RIGHT);
    lv_style_set_border_width(&style.focus, 2);
    lv_style_set_border_color(&style.focus, lv_color_hex(0xff931e));
    static const lv_style_prop_t style_prop[] =
        LV_STYLE_WIDTH,
        LV_STYLE_PROP_INV
    static lv_style_transition_dsc_t trans;
    lv_style_transition_dsc_init(
        &trans,
        style_prop,
        lv_anim_path_overshoot,
        200,
        0,
        nullptr
    lv_style_set_transition(&style.focus, &trans);
    lv_style_set_transition(&style.icon, &trans);
    lv_style_init(&style.info);
    lv_style_set_text_font(&style.info, ResourcePool::GetFont("bahnschrift_13"));
    lv_style_set_text_color(&style.info, lv_color_hex(0x999999));
    lv_style_init(&style.data);
    lv_style_set_text_font(&style.data, ResourcePool::GetFont("bahnschrift_13"));
    lv_style_set_text_color(&style.data, lv_color_white());
void SystemInfosView::Item_Create(
    item_t* item,
    lv_obj_t* par,
    const char* name,
    const char* img_src,
    const char* infos
    lv_obj_t* cont = lv_obj_create(par);
    lv_obj_remove_style_all(cont);
    lv_obj_set_width(cont, 220);
    lv_obj_clear_flag(cont, LV_OBJ_FLAG_SCROLLABLE);
    item->cont = cont;
    /* icon */
    lv_obj_t* icon = lv_obj_create(cont);
    lv_obj_remove_style_all(icon);
    lv_obj_clear_flag(icon, LV_OBJ_FLAG_SCROLLABLE);
    lv_obj_add_style(icon, &style.icon, 0);
    lv_obj_add_style(icon, &style.focus, LV_STATE_FOCUSED);
    lv_obj_set_style_align(icon, LV_ALIGN_LEFT_MID, 0);
    lv_obj_set_flex_flow(icon, LV_FLEX_FLOW_COLUMN);
        icon,
        LV_FLEX_ALIGN_SPACE_AROUND,
        LV_FLEX_ALIGN_CENTER,
    lv_obj_t* img = lv_img_create(icon);
    lv_img_set_src(img, ResourcePool::GetImage(img_src));
    lv_obj_t* label = lv_label_create(icon);
    lv_label_set_text(label, name);
    item->icon = icon;
    /* infos */
    label = lv_label_create(cont);
    lv_label_set_text(label, infos);
    lv_obj_add_style(label, &style.info, 0);
    lv_obj_align(label, LV_ALIGN_LEFT_MID, 75, 0);
    item->labelInfo = label;
    /* datas */
    lv_label_set_text(label, "-");
    lv_obj_add_style(label, &style.data, 0);
    lv_obj_align(label, LV_ALIGN_CENTER, 60, 0);
    item->labelData = label;
    lv_obj_move_foreground(icon);
    /* get real max height */
    lv_obj_update_layout(item->labelInfo);
    lv_coord_t height = lv_obj_get_height(item->labelInfo);
    height = LV_MAX(height, ITEM_HEIGHT_MIN);
    lv_obj_set_height(cont, height);
    lv_obj_set_height(icon, height);
Video here 【自制】这可能是你见过最强的DIY自行车码表_哔哩哔哩_bilibili at 00:27 seconds.
you could start by substituting :
to
lv_obj_t* cont = lv_obj_create(par, NULL);
lv_obj_t* icon = lv_obj_create(cont, NULL);
second argument of lv_obj_create in the old versions is the obj to copy from.
and go from there.
Thanks @H_Schwarz, I already figured out those parts, the one I’m having trouble with is mostly the animations, and
        root,
        icon,
And
