Have you ever encountered this kind of problem? As soon as this log appears, the interface will be dead.Could you tell me why?
V1IQ9Y2L63MRQ_M8J85CDC1
Nobody knows the solution?
Hi @axgmgm1 ,
This type of problem is usually caused by stack overflow, invalid memory accesses, lack of memory or an object being created which should be static going out of scope.
You will need to check your code carefully.
It is very hard to help you more with your problem without seeing your code.
Kind Regards,
Pete
Thank you,i’ll check my code carefully.
