Getting undefined symbols when porting from v6.0 to v6.0.2
Linker gives the following errors:
Undefined symbol lv_debug_check_null (referred from lv_font_fmt_txt.o).
Undefined symbol lv_debug_log_error (referred from lv_font_fmt_txt.o).
Undefined symbol lv_debug_check_style (referred from lv_obj.o).
Undefined symbol lv_vsnprintf (referred from lv_label.o).
What do you experience?
My code compiles when using version 6.0. But when I compile with version 6.0.2, I get undefined symbols.
What do you expect?
I expect the code to compile since the undefined symbols are being called from within the lvgl library code. I don’t expect that the library is broken in this way so I expect that there is something I need to update something when porting from v6.0 to v6.0.2.
I don’t think a code snippet is relevant here since it is a linker error having to do with functions declared in the lvgl library header files but not defined anywhere in the source code.
Use the ```c and ``` tags to format your code:
If possible, add screenshots and/or videos about the current issue.
Make sure all source files within the LittlevGL directory have been added to your Makefile or equivalent file list.
Ah, yes, thank you! Completely forgot that there might be new files in the new version.
