FYI about DMA issues on esp32
Hi @tve!
Could you explain the motivation for this change? What was the problem you were trying to solve?
There is a good reason it’s configured as half-duplex.
See: Can't mount SD card and display at the same time when sharing the same SPI bus · Issue #69 · lvgl/lv_binding_micropython · GitHub
In a nutshell, Full-duplex transactions are not compatible with the dummy bit workaround and limit SPI speed to 26MHz.
On the other hand, half-duplex with the dummy bit workaround allow speeds up to 80MHz. I usually use the display driver at 40MHz.
It’s possible, however, to add another parameter to ili9341 constructor to configure it as full-duplex when needed, if it helps to solve some problems and when the SPI speed is less important.
If you want to help, we always welcome PRs!
