FT6336 + ESP32 - Touch misalignment
Square Line Studio project has TOUCH MISALIGMENT.
Running the LVGL WIDGETS example for the same board and display (ESP32 + MSP3526) works fine. So I guess the issue is with the the exported files/Square Line config.
Arduino IDE 2.3.2
ESP32 (epressif 3.0.1 core)
MSP3526 module (ST7796 tft isplay + FT6336 touch)
8.3.11
I want touch to correspond to where widgets are placed. Currently they are misaligned.
Both display and touch are set to the same W/H ratio.
Also, running the LVGL example presents no issue, so I guess the problem is with the UI exported files from SQLN Studio
FROM .INO FILE:
/* Reading input device (simulated encoder here) */
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
  if (touch_has_signal())
    if (touch_touched())
      /*Set the coordinates*/
      data->point.x = touch_last_x;
      data->point.y = touch_last_y;
    else if (touch_released())
FROM TOUCH.H
#include <FT6336.h>
//#include <FT6X36.h>
//#define TOUCH_SWAP_XY
#define TOUCH_MAP_X1 0
#define TOUCH_MAP_X2 320
#define TOUCH_MAP_Y1 0
#define TOUCH_MAP_Y2 480
int touch_last_x = 0, touch_last_y = 0;
unsigned short int width=0, height=0, rotation,min_x=0,max_x=0,min_y=0,max_y=0;
FT6336 ts = FT6336(TOUCH_FT6336_SDA, TOUCH_FT6336_SCL, TOUCH_FT6336_INT, TOUCH_FT6336_RST, max(TOUCH_MAP_X1, TOUCH_MAP_X2), max(TOUCH_MAP_Y1, TOUCH_MAP_Y2));
void touch_init(unsigned short int w, unsigned short int h,unsigned char r)
  width = w;
  height = h;
  switch (r)
    case ROTATION_NORMAL:
      case ROTATION_INVERTED:
        min_x = TOUCH_MAP_X1;
        max_x = TOUCH_MAP_X2;
        min_y = TOUCH_MAP_Y1;
        max_y = TOUCH_MAP_Y2;
      break;
    case ROTATION_LEFT:
      case ROTATION_RIGHT:
        min_x = TOUCH_MAP_Y1;
        max_x = TOUCH_MAP_Y2;
        min_y = TOUCH_MAP_X1;
        max_y = TOUCH_MAP_X2;
      break;
    default:
    break;
  ts.begin();
  ts.setRotation(r);
bool touch_touched(void)
   ts.read();
  if (ts.isTouched)
    #if defined(TOUCH_SWAP_XY)
        touch_last_x = map(ts.points[0].y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, width - 1);
        touch_last_y = map(ts.points[0].x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, height - 1);
    #else
        touch_last_x = map(ts.points[0].x, min_x, max_x, 0, width - 1);
        touch_last_y = map(ts.points[0].y, min_y, max_y, 0, height - 1);
//    Serial.print("x = ");
//    Serial.print(touch_last_x);
//    Serial.print(", y = ");
//    Serial.print(touch_last_y);
//    Serial.print("\r\n");
    return true;
    return false;
bool touch_has_signal(void)
  return true;
bool touch_released(void)
  return true;
FT6336.h
#ifndef FT6336_H
  #define FT6336_H
  #include "Arduino.h"
  #include <Wire.h>
  #define FT6336_ADDR  (uint8_t)0x38
  #define ROTATION_LEFT       (uint8_t)3
  #define ROTATION_INVERTED   (uint8_t)2
  #define ROTATION_RIGHT      (uint8_t)1
  #define ROTATION_NORMAL     (uint8_t)0
  #define FT6336_DEVIDE_MODE  (uint8_t)0x00
  #define FT6336_TD_STATUS    (uint8_t)0x02
  #define FT6336_TOUCH_1      (uint8_t)0X03
  #define FT6336_TOUCH_2      (uint8_t)0X09
  #define FT6336_TOUCH_REG        {FT6336_TOUCH_1, FT6336_TOUCH_2}
  #define FT6336_ID_G_CIPHER_MID    (uint8_t)0x9F    //default: 0x26
  #define FT6336_ID_G_CIPHER_LOW    (uint8_t)0XA0    //0x01:FT6336G, 0x02:FT6336U
  #define FT6336_ID_G_LIB_VERSION   (uint8_t)0xA1
  #define FT6336_ID_G_CIPHER_HIGH     (uint8_t)0XA3  //default: 0x64
  #define FT6336_ID_G_MODE            (uint8_t)0XA4
  #define FT6336_ID_G_FOCALTECH_ID    (uint8_t)0XA8  //default: 0x11
  #define FT6336_ID_G_THGROUP         (uint8_t)0X80
  #define FT6336_ID_G_PERIODACTIVE    (uint8_t)0X88
  class TP_Point
    public:
      TP_Point(void);
      TP_Point(uint8_t id, uint16_t x, uint16_t y, uint16_t size);
      bool operator==(TP_Point);
      bool operator!=(TP_Point);
      uint8_t id;
      uint16_t x;
      uint16_t y;
      uint8_t size;
  class FT6336
    public:
      FT6336(uint8_t _sda, uint8_t _scl, uint8_t _int, uint8_t _rst, uint16_t _width, uint16_t _height);
      void begin(uint8_t _addr=FT6336_ADDR);
      uint8_t reset();
      void setRotation(uint8_t rot);
      void read(void);
      uint8_t touches = 0;
      bool isTouched = false;
      TP_Point points[2];
    private:
      // static void ARDUINO_ISR_ATTR onInterrupt();
      TP_Point readPoint(uint8_t *data);
      void writeByteData(uint16_t reg, uint8_t val);
      uint8_t readByteData(uint16_t reg);
      void writeBlockData(uint16_t reg, uint8_t *val, uint8_t size);
      void readBlockData(uint8_t *buf, uint16_t reg, uint8_t size);
      uint8_t rotation = ROTATION_NORMAL;
      uint8_t addr;
      uint8_t pinSda;
      uint8_t pinScl;
      uint8_t pinInt;
      uint8_t pinRst;
      uint16_t width;
      uint16_t height;
FT6336.cpp
#include <FT6336.h>
#include <Wire.h>
FT6336::FT6336(uint8_t _sda, uint8_t _scl, uint8_t _int, uint8_t _rst, uint16_t _width, uint16_t _height) :
              pinSda(_sda), pinScl(_scl), pinInt(_int), pinRst(_rst), width(_width), height(_height)
void FT6336::begin(uint8_t _addr)
  addr = _addr;
  Wire.begin(pinSda, pinScl);
  if(reset())
    Serial.print("touch ic error!\r\n");
uint8_t FT6336::reset()
  uint8_t tmp[2];
  pinMode(pinInt, INPUT);
  pinMode(pinRst, OUTPUT);
  digitalWrite(pinInt, 1);
  digitalWrite(pinRst, 1);
  delay(20);
  digitalWrite(pinRst, 0);
  delay(20);
  delay(500);
  readBlockData(&tmp[0], FT6336_ID_G_FOCALTECH_ID, 1);
  if(tmp[0] != 0x11)
    return 1;
  readBlockData(tmp, FT6336_ID_G_CIPHER_MID, 2);
  if(tmp[0] != 0x26)
    return 1;
  if((tmp[1]!=0x00)&&(tmp[1]!=0x01)&&(tmp[1]!=0x02))
    return 1;
  readBlockData(&tmp[0], FT6336_ID_G_CIPHER_HIGH, 1);
  if(tmp[0] != 0x64)
    return 1;
  return 0;
void FT6336::setRotation(uint8_t rot)
  rotation = rot;
void FT6336::read(void)
  uint8_t data[4];
  uint8_t pointInfo = readByteData(FT6336_TD_STATUS);
  touches = pointInfo;
  isTouched = (touches > 0 && touches < 3);
  if (isTouched)
    for (uint8_t i=0; i<touches; i++)
      readBlockData(data, FT6336_TOUCH_1 + i * 6, 4);
      points[i] = readPoint(data);
TP_Point FT6336::readPoint(uint8_t *data)
  uint16_t temp;
  uint8_t id = data[2] >> 4;
  uint16_t x = (uint16_t)((data[0]&0x0F)<<8) + data[1];
  uint16_t y = (uint16_t)((data[2]&0x0F)<<8) + data[3];
  switch (rotation)
      x = x;
      y = y;
    break;
    case ROTATION_LEFT:
      temp = x;
      x = height - y;
      y = temp;
    break;
      x = width - x;
      y = height - y;
    break;
      temp = x;
      x = y;
      y = width - temp;
    break;
    default:
    break;
  return TP_Point(id, x, y, 0);
void FT6336::writeByteData(uint16_t reg, uint8_t val)
  Wire.beginTransmission(addr);
 // Wire.write(highByte(reg));
  Wire.write(lowByte(reg));
  Wire.write(val);
  Wire.endTransmission();
uint8_t FT6336::readByteData(uint16_t reg)
  uint8_t x;
  Wire.requestFrom(addr, (uint8_t)1);
  x = Wire.read();
  return x;
void FT6336::writeBlockData(uint16_t reg, uint8_t *val, uint8_t size)
  // Wire.write(val, size);
  for (uint8_t i=0; i<size; i++) {
    Wire.write(val[i]);
void FT6336::readBlockData(uint8_t *buf, uint16_t reg, uint8_t size)
  Wire.requestFrom(addr, size);
    buf[i] = Wire.read();
TP_Point::TP_Point(void)
  id = x = y = size = 0;
TP_Point::TP_Point(uint8_t _id, uint16_t _x, uint16_t _y, uint16_t _size)
  id = _id;
  x = _x;
  y = _y;
  size = _size;
bool TP_Point::operator==(TP_Point point)
  return ((point.x == x) && (point.y == y) && (point.size == size));
bool TP_Point::operator!=(TP_Point point)
  return ((point.x != x) || (point.y != y) || (point.size != size));
20240607_150200_1_1_1.mp4 [resize output image]
hi, it’s all about the FT6336, contact the manufacturer to calibrate individually for each. it’s a big surprise…
Hi @TigoTas
where did you get the library for FT6336?
I’m struggling to get FT6336U working, arduino lib shows some strange touches at 2200; 2200 coordinates
