From Figma to LVGL to Real Hardware — Testing a More Direct Workflow
I’ve been testing a workflow for taking an HMI from an early UI design to real embedded hardware.
The current flow is roughly:
Idea / sketch → requirements → interaction & state → Figma → LVGL → hardware
The interesting part is not generating LVGL code itself. Tools already exist for that.
The harder part is keeping the UI structure, interaction logic, state model and hardware bindings consistent when moving from design into an embedded project.
We now have this flow running on real ArtInChip hardware, and I’d like to test it with more real-world HMI cases.
I’m especially interested in projects where:
  • the UI already exists in Figma or as a sketch
  • the target uses LVGL
  • there are buttons, states, sensor values, GPIO, Modbus, MQTT or similar bindings
  • the goal is a working prototype on real hardware
I’m not trying to replace normal LVGL development. The goal is to reduce the repetitive work between UI design and embedded implementation.
If anyone has a small HMI project or UI that would make a good test case, I’d be happy to try it and share what works — and what still needs manual engineering.
OpenHMI Network: openhmi.network
Hi @DavidDu,
Have you tried testing this EV Charge demo?
Hi halyssonJr, Thanks for sharing this.
I can open the Figma link, but it looks like a broader Figma Flow companion/community file rather than a dedicated EV charger design.
Which page or frame in the file are you referring to as the EV Charge demo?
Once I have the exact frame, I’d be happy to run it through the OpenHMI workflow and test the path from Figma → interaction/state analysis → LVGL → real hardware.
Hi David,
Left corner, click on the Screen page.
Thanks, this is a good case.
This is exactly the kind of workflow we’re building OpenHMI for — taking a Figma design and getting a working HMI prototype onto real embedded hardware quickly.
We’ll test the flow with this design and share a short hardware demo video once it’s running.
Perfect, thanks S2
Our first demo is running on hardware
Congras, @DavidDu
Can we use this for public demo?
Yes, sure
