I`m trying to make work the example in LVGL_Arduino.ino
But when I try to compile the sketch I have the following exception:
sketch\preubaLVGL.ino.cpp.o:(.literal._Z5setupv+0x28): undefined reference to
lv_ex_btn_1' sketch\preubaLVGL.ino.cpp.o: In function
setup()’:
C:\Users\alvar\Documents\Arduino\preubaLVGL/preubaLVGL.ino:103: undefined reference to `lv_ex_btn_1’
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compilando para la tarjeta DOIT ESP32 DEVKIT V1.
I include the “lv_examples-master/lv_examples.h” but i can’t compile
ESP32 NODE MCU and ILI9341 with the connections of az touch board
Learn to use the librarie
I tryed work the example of slider in the librarie version 3.0, downloaded from the manager libraries of arduinoID but I couldn’t work the touch, I saw the example well but the touch didn’t work
#include <lvgl.h>
#include <TFT_eSPI.h>
#include "lv_examples-master/lv_examples.h"
int screenWidth = 240;
int screenHeight = 320;
#if USE_LV_LOG != 0
/* Serial debugging */
void my_print(lv_log_level_t level, const char * file, uint32_t line, const char * dsc)
Serial.printf("%s@%d->%s\r\n", file, line, dsc);
Serial.flush();
/* Display flushing */
tft.startWrite();
tft.pushColors(&color_p->full, w * h, true);
tft.endWrite();
lv_disp_flush_ready(disp);
/*Read the touchpad*/
bool my_touchpad_read(lv_indev_drv_t * indev_driver, lv_indev_data_t * data)
uint16_t touchX, touchY;
bool touched = tft.getTouch(&touchX, &touchY, 600);
if(!touched)
return false;
if(touchX>screenWidth || touchY > screenHeight)
Serial.println("Y or y outside of expected parameters..");
Serial.print("y:");
Serial.print(touchX);
Serial.print(" x:");
Serial.print(touchY);
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print("Data x");
Serial.println(touchX);
Serial.print("Data y");
Serial.println(touchY);
return false; /*Return `false` because we are not buffering and no more data to read*/
void setup()
#if USE_LV_LOG != 0
lv_log_register_print_cb(my_print); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation(1); /* Landscape orientation */
uint16_t calData[5] = { 275, 3620, 264, 3532, 1 };
tft.setTouch(calData);
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 320;
disp_drv.ver_res = 240;
disp_drv.buffer = &disp_buf;
lv_indev_drv_t indev_drv;
lv_ex_btn_1();
void loop()
delay(5);
What can I do to test the librarie?
