ESP32 in Arduino IDE
v 7.11
I would like to change color of the wifi symbol when value of the glolbal variable change.
I tried to find some examples, but so far none of them point me to the right direction.
Ok, but this will be just one time change, right? Sorry, I probably not made it clear, that I want to recolor symbol if value of the variable change. So if I´m connected, it will be green and if I lost connection, it will be grey. That is the reason why I try it via event callback.
Simple way is put this instructions inside main loop:
if ((WiFi.status() != WL_CONNECTED) ) {
change wifi label colour here
and call WiFi.reconnect(); if you want reconnect automatically // in wifi reconnect you can put default colour if connected
or use a handler that change colours when status wifi change for example this:
void Wifi_disconnected(WiFiEvent_t event, WiFiEventInfo_t info){
Serial.println("Disconnected from WIFI access point");
Serial.print("WiFi lost connection. Reason: ");
Serial.println(info.disconnected.reason);
Serial.println("Reconnecting...");
change label colours
