Hello,
Thanks for your anwser. after attempt and attempt …i built a LV_COLOR_16 Version it working without SWAP_FLAG=1
But it seem CFLAGS parameter is not taking into account … (so strange)
Now i’m attempt to display something
i added the drivers ST7786 made by @ kdschlosser
https://forum.lvgl.io/t/st7796s-driver-lv-micropython/4123/9
But without success. The driver start and initalize but i have a white screen.
So i decided to use the ST77xx_test.py and it is working with low level command.
https://github.com/lvgl/lv_binding_micropython/blob/master/driver/generic/st77xx-test.py
My script initial script if you can give me your opinion !
import machine
import sys
sys.path.append('.')
import espidf as esp
import lvgl as lv
import utime
from st7796 import *
# init display
disp = st7796(
miso=23,
mosi=19,
clk=18,
cs=5,
dc=27,
rst=-1,
backlight=12,
power=-1,
width=480,#480
height=320,#320
rot=0, #PORTRAIT
# Create a screen with a button and a label
scr = lv.obj()
btn = lv.btn(scr)
btn.align_to(lv.scr_act(), lv.ALIGN.CENTER, 0, 0)
label = lv.label(btn)
label.set_text("Hello World!")
# Load the screen
lv.scr_load(scr)
The driver class
class st7796(ili9XXX.ili9XXX):
xxx from the link
Thanks for your time
Arnaud
