When compiling on Eclipse, i get an error as follows: unknown warning option ‘-Wmaybe-uninitialized’; did you mean ‘-Wuninitialized’?
Eclipse - with lvgl-sdl
That it compiles without these warnings. - it does compile however.
Searched the inernet for similar warnings, but did not find the solution related to Eclipse. This happens dring the paid lessons from the lvgl academy - part course material integration
and ```
tags:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "../../course_main.h"
#ifdef COMPLETED
static lv_chart_series_t *series;
lv_obj_t* chart;
int get_temprature(void)
return rand() % 100;
void task_cb(lv_task_t task)
int reading = get_temprature();
lv_chart_set_next(chart,series,reading);
void task(void)
lv_task_t* task = lv_task_create(task_cb,500,LV_TASK_PRIO_MID,NULL);
chart = lv_chart_create(lv_scr_act(), NULL);
series = lv_chart_add_series(chart, LV_COLOR_BLUE);
20:09:41 **** Incremental Build of configuration Debug for project lv_sim_eclipse_sdl ****
make all
Building file: …/simulator/excercise/_6_tasks/_6_task.c
Invoking: Cross GCC Compiler
gcc -I"/Users/erikschott/git/lv_sim_eclipse_sdl" -O0 -g3 -Wall -c -fmessage-length=0 -Wall -Wmaybe-uninitialized -MMD -MP -MF"simulator/excercise/_6_tasks/_6_task.d" -MT"simulator/excercise/_6_tasks/_6_task.o" -o “simulator/excercise/_6_tasks/_6_task.o” “…/simulator/excercise/_6_tasks/_6_task.c”
warning: unknown warning option ‘-Wmaybe-uninitialized’; did you mean ‘-Wuninitialized’? [-Wunknown-warning-option]
1 warning generated.
Finished building: …/simulator/excercise/_6_tasks/_6_task.c
