Dynamic autofit V8
I try to Dynamically adapt the heigh of a object according to the size of not hidden childrens.
ESP32
V8.3.10
I want the heigh of the object adapts when I hidde or display a child.
I tryed using lv_obj_set_height(cont, LV_SIZE_CONTENT);
lv_obj_t *cont = lv_obj_create(lv_scr_act());
lv_obj_set_width(cont, 200);
lv_obj_align(cont, LV_ALIGN_TOP_MID, 0, 20);
lv_obj_t *label;
lv_obj_t *btn1 = lv_btn_create(cont);
lv_obj_align(btn1, LV_ALIGN_TOP_MID, 0, 10);
label = lv_label_create(btn1);
lv_obj_t *btn2 = lv_btn_create(cont);
label = lv_label_create(btn2);
lv_label_set_text(label, "Toggled");
lv_obj_align_to(btn2, btn1, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
while(true){
    lv_task_handler();
    delay(5);
    if((millis()/1000) % 2)
      lv_obj_add_flag(btn2, LV_OBJ_FLAG_HIDDEN);
      lv_obj_clear_flag(btn2, LV_OBJ_FLAG_HIDDEN);
LV_ALIGN_OUT_BOTTOM_MID doesn’t work well with LV_SIZE_CONTENT because it would cause a circular dependency: the bottom position of cont depends on btn2, and btn2 should be aligned to the bottom of cont.
Try using e.g.
lv_obj_align(btn2, LV_ALIGN_TOP_MID, 0, 100);
thanks for your reply
I tried it, but cont is not resized :frowning:
I gave a simple example to show the behavior.
but my real need is several buttons and dropdown which should be display or hidden according to user settings, so a fixed position would not be compatible.
in V7 I was able to do it with lv_btn_set_fit2(btn2, LV_FIT_PARENT, LV_FIT_TIGHT); // autorise l'adaptation dynamique but I got fit2 was not available anymore in V8
An other observation :
in my global project, I have different screens, when I switch to an other screen and come back to this one, the size is adapted
Just an idea.
Change you code to toggle LV_OBJ_FLAG_HIDDEN only ONCE every 0.5 sec. and also call
lv_obj_invalidate( cont ) once right after to have “cont” redrawn by lv_task_handler().
HTH JJ7
