If generated font bpp is 3 any text is not drawn
Environment: SDL, SAMS70 (behavior is the same)
LVGL 9.2.2
After migration from 8.3.0 to 9.2.2 I faced with problem there are no any texts on most gui controls. My investigation show that difference is only in generated data by lv_font_conv below.
#if LVGL_VERSION_MAJOR >= 8
static const lv_font_fmt_txt_dsc_t font_dsc = {
#else
static lv_font_fmt_txt_dsc_t font_dsc = {
.glyph_bitmap = glyph_bitmap,
.glyph_dsc = glyph_dsc,
.cmaps = cmaps,
.kern_dsc = &kern_classes,
.kern_scale = 16,
.cmap_num = 3,
.bpp = 3,
.kern_classes = 1,
.bitmap_format = 1,
#if LVGL_VERSION_MAJOR == 8
.cache = &cache
This rle compressed data. And other key is bpp = 3. I would like to emphasize that this code is fine for 8.3.0.
During debug i found in function draw_letter_cb (file lv_draw_sw_letter.c:67) there is no implementation for drawing letter of bpp = 3. In fact glyph_draw_dsc->format is value of font bpp. (See in code above). draw_letter_cb just skips this case of bpp 3. In version 8.3.0 letter drawing is implemented in function draw_letter_normal (lv_draw_sw_letter.c:165) there is a line which solve problem of bpp = 3 in line 175:
if(bpp == 3) bpp = 4;
I tried to add similar code in 9.3.0 and it solved problem.
Question: is this behavior ok or this is bug?
Is there a workaround to make it work with bpp =3?
