lv_obj_set_style_radius(T1, LV_RADIUS_CIRCLE, 0);
lv_obj_set_size(T1, 45, 45);
The above works, but if I change size to anything else like 40,40, I see inside
my circle (which has white background) a vertical, and horizontal scroll bars.
Why am I getting these scroll bars ?
If what I am doing is correct then maybe my question should be:
How do I get rid of auto scrolling in objects.
None
Scrollbars appear when a child object is larger than its parent object. They can be disabled for an object by using: lv_obj_set_scrollbar_mode(lvgl_object_name, LV_SCROLLBAR_MODE_OFF);
Yes, this works.
However, it appears that LV_SCROLLBAR_MODE_OFF only makes scrollbars disappear, but does NOT stop object from scrolling (for example by hand).
Here I created a window object, and near the bottom edge I placed a label. I used LV_SCROLLBAR_MODE_OFF, and yes, no scrollbars visible, but I can swipe the window up/down with my finger on touch screen:
