The example in https://github.com/littlevgl/docs/blob/master/en/overview/layer.md contains:
lv_btn_set_fit(btn1, true, true); /*Enable to automatically set the size according to the content*/
This is not how lv_btn_set_fit() is to be used, so I assume this is an older syntax.
JW
Thanks. It should be fixed here.
Hi embeddedt,
static void lv_btn_set_fit(lv_obj_t *btn, lv_fit_t fit) takes only one LV_FIT_xxx parameter (i.e. two parameters altogether). It would be lv_btn_set_fit2() to take two.
Thanks,
Thanks for the correction.
