Disabling keys in a messagebox doesnt work
After i press the yes or no key in a messagebox, i need these keys to be disabled.
lv_obj_t *ftr = lv_msgbox_get_footer(mbox);
lv_obj_add_state(ftr, LV_STATE_DISABLED);
/*OK key callback*/
void btn100DensOK_cb(lv_event_t *e)
  lv_obj_t *mbox = (lv_obj_t *)lv_event_get_user_data(e);
  lv_obj_t *obj = lv_msgbox_get_content(mbox);
   lv_obj_t *label = lv_obj_get_child(obj, 0);
  lv_label_set_text(label, "\n\nWait....");
  msgbox2close = mbox;
  set100Tmout = MBOX_TMOUT;
  return;
  • MCU/MPU/Board: ESP32S3
  • LVGL version: See lv_version.h 9.4
I have a messagebox where when i press ok, i have a delay before it closes (MBOX_TMOUT aboxe).
I need the ok/cancel keys to be disabled during this time.
I am passing the messagebox to the keys callback, then doing this:
but it doesnt disable the keys.
Why is this ?
How can I acheive this ?
Thanks,
–Royce
You could try maybe getting the children of the message box footer and disable them.
    // Get footer and disable its buttons
    if(ftr) {
        uint32_t i;
        uint32_t child_cnt = lv_obj_get_child_count(ftr);
        for(i = 0; i < child_cnt; i++) {
            lv_obj_t *btn = lv_obj_get_child(ftr, i);
            lv_obj_add_state(btn, LV_STATE_DISABLED);
Can you check if this works for you?
Yes this works.
Thank you!
Logically my code should work too (disabling the parent(footer) should disable all children(buttons).
Could it be a bug ?
I checked the internals of lv_obj_add_state: lvgl/src/core/lv_obj.c at master · lvgl/lvgl · GitHub
void lv_obj_add_state(lv_obj_t * obj, lv_state_t state)
    LV_ASSERT_OBJ(obj, MY_CLASS);
    lv_state_t new_state = obj->state | state;
    if(obj->state != new_state) {
        update_obj_state(obj, new_state);
        if(lv_obj_has_flag(obj, LV_OBJ_FLAG_STATE_TRICKLE)) {
            lv_obj_children_add_state(obj, state);
If the parent, in this case the message box, has the flag LV_OBJ_FLAG_STATE_TRICKLE, state changes should propagate to children as well.
So probably this is a better solution than my previous one. It is more the “LVGL way” of handling it.
