Hi, i am following the animations video tutorial in the LVGL academy however the ‘toast’ is still active after the opacity is set to 0, therefore any buttons which were placed in the same place as the pop up is now covered by the 0 opacity alert.
When i try to delete the alert after the opacity is set to 0, it does not reduce the opacity graduallly and rather just deletes it instantly.
VS Sim
latest
delete the alert after the fade out transition
void change_opa(lv_obj_t* obj, uint16_t val)
lv_obj_set_style_local_opa_scale(obj, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, val);
void ready_cb(lv_anim_t* old_anim)
lv_obj_t* alert = (lv_obj_t*)old_anim->var;
lv_anim_t a;
lv_anim_init(&a);
lv_anim_set_var(&a, alert);
lv_anim_set_exec_cb(&a, (lv_anim_exec_xcb_t)change_opa);
lv_anim_set_values(&a, 255, 50);
lv_anim_set_time(&a, 1000);
lv_anim_set_delay(&a, 1000);
lv_anim_start(&a);
lv_obj_del_async(alert);
animready = TRUE;
void message_alert(char* message)
animready = FALSE;
lv_obj_t* alert = lv_obj_create(lv_scr_act(), NULL);
uint16_t height = 30;
lv_obj_set_size(alert, lv_obj_get_width_fit(lv_scr_act()), height);
lv_obj_set_y(alert, lv_obj_get_height_fit(lv_scr_act()) - height);
lv_obj_set_style_local_bg_color(alert, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_RED);
lv_obj_set_style_local_text_color(alert, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_WHITE);
lv_obj_t* message_label = lv_label_create(alert, NULL);
lv_label_set_text(message_label, message);
lv_obj_align(message_label,NULL, LV_ALIGN_CENTER, 0, 0);
lv_anim_t a;
lv_anim_init(&a);
lv_anim_set_exec_cb(&a, (lv_anim_exec_xcb_t)lv_obj_set_y);
lv_anim_set_values(&a, lv_obj_get_height_fit(lv_scr_act()), lv_obj_get_height_fit(lv_scr_act()) - height);
lv_anim_start(&a);
lv_anim_set_ready_cb(&a, ready_cb);
//lv_anim_set_playback_time(&a, 1000);
//lv_anim_set_playback_delay(&a, 1000);
void btn_check(lv_obj_t* lightingbuttonA, lv_event_t event)
lv_btn_state_t state = lv_btn_get_state(lightingbuttonA);
if ((state == LV_BTN_STATE_RELEASED) && (animready == TRUE))
message_alert("You Are Not Authorised To Use This Device");
