Custom Slider Causes An Error
I have two screens, I am changing between them with below code without any touch event.
setup_screen_1();
lv_screen_load_anim(screen_1, LV_SCR_LOAD_ANIM_NONE, 0, 0, true);
Screens change successfully if there is no custom style slider. Even if there is a slider ,it changes in success. I have added custom slider as below:
    /*Create a transition*/
   static const lv_style_prop_t props[] = {LV_STYLE_BG_COLOR, 0};
   static lv_style_transition_dsc_t transition_dsc;
    lv_style_transition_dsc_init(&transition_dsc, props, NULL, 0, 0, NULL);
    static lv_style_t style_main;
    static lv_style_t style_indicator;
    static  lv_style_t style_knob;
    lv_style_init(&style_main);
    lv_style_set_bg_opa(&style_main, LV_OPA_COVER);
    lv_style_set_bg_color(&style_main, lv_color_hex(0xa2a4a7));
    lv_style_set_radius(&style_main, LV_RADIUS_CIRCLE);
    lv_style_set_pad_ver(&style_main, -2); /*Makes the indicator larger*/
    lv_style_init(&style_indicator);
    lv_style_set_bg_opa(&style_indicator, LV_OPA_COVER);
    lv_style_set_bg_color(&style_indicator, lv_color_hex(0x113dd8));
    lv_style_set_radius(&style_indicator, LV_RADIUS_CIRCLE);
    lv_style_set_transition(&style_indicator, &transition_dsc);
    lv_style_init(&style_knob);
    lv_style_set_bg_opa(&style_knob, LV_OPA_COVER);
    lv_style_set_bg_color(&style_knob, lv_color_hex(0xffffff));
    lv_style_set_border_color(&style_knob, lv_color_hex(0x032ba1));
    lv_style_set_border_width(&style_knob, 5);
    lv_style_set_radius(&style_knob, LV_RADIUS_CIRCLE);
    lv_style_set_pad_all(&style_knob, 15); /*Makes the knob larger*/
    lv_style_set_transition(&style_knob, &transition_dsc);
    /*Create a slider and add the style*/
    slider_volume = lv_slider_create(screen_1);
    lv_obj_remove_style_all(slider_volume);        /*Remove the styles coming from the theme*/
    lv_obj_add_style(slider_volume, &style_main, LV_PART_MAIN);
    lv_obj_add_style(slider_volume, &style_indicator, LV_PART_INDICATOR);
    lv_obj_add_style(slider_volume, &style_knob, LV_PART_KNOB);
	lv_slider_set_range(slider_volume, 0, 100);
	lv_slider_set_mode(slider_volume, LV_SLIDER_MODE_NORMAL);
	lv_slider_set_value(slider_volume, 50, LV_ANIM_OFF);
	lv_obj_set_pos(slider_volume, 334, 443);
	lv_obj_set_size(slider_volume, 450, 10);
After some time, I see below log in console. How should I modify my code to not get this error?
[Error]	(111.356, +111356)	 img_draw_core: Asserted at expression: tmp_buf != NULL Out of memory lv_draw_sw_img.c:275
IMXRT 1176
v9.0
I want to change pages with custom slider successfully
I have tried styles to add different objects in pages, the situation is same, I get the same error. So it seems it is about lv_style_t objects.
When I use local styles it changes as expected without error but I am not sure if it works robust or not.
lv_obj_set_style_bg_opa(slider_volume, LV_OPA_COVER, LV_PART_MAIN);
lv_obj_set_style_bg_color(slider_volume, lv_color_hex(0xa2a4a7), LV_PART_MAIN);
lv_obj_set_style_radius(slider_volume, LV_RADIUS_CIRCLE, LV_PART_MAIN);
lv_obj_set_style_pad_ver(slider_volume, -2, LV_PART_MAIN); /*Makes the indicator larger*/
lv_obj_set_style_bg_color(slider_volume, lv_color_hex(0x113dd8), LV_PART_INDICATOR);
lv_obj_set_style_bg_opa(slider_volume, LV_OPA_COVER, LV_PART_INDICATOR);
lv_obj_set_style_radius(slider_volume, LV_RADIUS_CIRCLE, LV_PART_INDICATOR);
