Correct way to add a custom theme without putting in lvgl project files
Is it documented how to add a custom theme correctly? I created one, but I have to put it in the lv_themes directory to get all the required includes. I don’t see any mention of custom themes in the 6.0 docs
arm-gcc on I.MXRT1052
Adding a custom theme, and keeping it separate from the lvgl core files
Placing the theme file directly into the lvgl lv_themes file structure and modifying lv_conf.h to reference it.
There is no specific code for the question
There is no specific screenshot for the question.
You don’t really need to put it in lv_themes… you should be able to remove the #if LV_USE_THEME/#endif conditions at the top and bottom of the file and just use it.
And you can just include lvgl/lvgl.h at the top of the file as normal.
BTW: Thank you for filling out the template.
