Clearing Label causes Data Abort Error
Cortex A9 *processor, GCC
5.0
Clear a Label
Use obj_delete, delete the pointer itself, set the label text again
lv_obj_t * autoWinOp;
lv_obj_t * autoWinAlly;
lv_obj_t * autonOp;
lv_obj_t * autonAlly;
lv_obj_t * skills;
const char* a = "hello";
lv_obj_t * autoWinOpLabel;
lv_obj_t * autoWinAllyLabel;
lv_obj_t * autonOpLabel;
lv_obj_t * autonAllyLabel;
lv_obj_t * skillsLabel;
lv_obj_t * autonCurrent;
int autonFunc = 0;
lv_style_t myButtonStyleREL; //relesed style
lv_style_t myButtonStylePR; //pressed style
lv_res_t btn_click_action(lv_obj_t * btn)
    uint8_t id = lv_obj_get_free_num(btn); //id usefull when there are multiple buttons
	if(id == 0){
		autonFunc = 0;
		//lv_obj_del(autonCurrent);
		delete autonCurrent;
		autonCurrent = NULL;
		lv_obj_t * autonCurrent = lv_label_create(lv_scr_act(), NULL);
		lv_obj_align(autonCurrent, NULL, LV_ALIGN_CENTER, -20,0);
		lv_label_set_text(autonCurrent, "Current Auton: Auto Win Op");
	else if(id == 1){
		autonFunc = 1;
		lv_label_set_text(autonCurrent, "Current Auton: Auto Win Ally");
	else if(id == 2){
		autonFunc = 2;
		//lv_obj_t * autonCurrent = lv_label_create(lv_scr_act(), NULL);
		//lv_obj_align(autonCurrent, NULL, LV_ALIGN_CENTER, -20,0);
		lv_label_set_text(autonCurrent, "");
	else if(id == 3){
		autonFunc = 3;
		lv_label_set_text(autonCurrent, "Current Auton: Ally");
	else if(id == 4){
		autonFunc = 4;
		//lv_label_set_text(autonCurrent, "Current Auton: Skills");
		a = "Skills";
    return LV_RES_OK;
void on_center_button() {
 * Runs initialization code. This occurs as soon as the program is started.
 * All other competition modes are blocked by initialize; it is recommended
 * to keep execution time for this mode under a few seconds.
void initialize() {
	lv_style_copy(&myButtonStyleREL, &lv_style_plain);
    myButtonStyleREL.body.main_color = LV_COLOR_MAKE(255,81,47);
    myButtonStyleREL.body.grad_color = LV_COLOR_MAKE(221, 36, 118);
    myButtonStyleREL.body.radius = 0;
    myButtonStyleREL.text.color = LV_COLOR_MAKE(255, 255, 255);
    lv_style_copy(&myButtonStylePR, &lv_style_plain);
    myButtonStylePR.body.main_color = LV_COLOR_MAKE(255, 0, 0);
    myButtonStylePR.body.grad_color = LV_COLOR_MAKE(0, 0, 255);
    myButtonStylePR.body.radius = 0;
    myButtonStylePR.text.color = LV_COLOR_MAKE(255, 255, 255);
    autoWinOp = lv_btn_create(lv_scr_act(), NULL); //create button, lv_scr_act() is deafult screen object
	lv_obj_set_free_num(autoWinOp, 0); //set button is to 0
	lv_btn_set_action(autoWinOp, LV_BTN_ACTION_CLICK, btn_click_action); //set function to be called on button click
	lv_btn_set_style(autoWinOp, LV_BTN_STYLE_REL, &myButtonStyleREL); //set the relesed style
	lv_btn_set_style(autoWinOp, LV_BTN_STYLE_PR, &myButtonStylePR); //set the pressed style
	lv_obj_set_size(autoWinOp, 200, 50); //set the button size
	lv_obj_align(autoWinOp, NULL, LV_ALIGN_IN_TOP_LEFT, 10, 10); //set the position to top mid
	autoWinOpLabel = lv_label_create(autoWinOp, NULL); //create label and puts it inside of the button
	lv_label_set_text(autoWinOpLabel, "Auto Win Op"); //sets label text
	lv_obj_align(autoWinOpLabel, NULL, LV_ALIGN_CENTER, 0, 0); //set the position to center
	autoWinAlly = lv_btn_create(lv_scr_act(), NULL); //create button, lv_scr_act() is deafult screen object
	lv_obj_set_free_num(autoWinAlly, 1); //set button is to 0
	lv_btn_set_action(autoWinAlly, LV_BTN_ACTION_CLICK, btn_click_action); //set function to be called on button click
	lv_btn_set_style(autoWinAlly, LV_BTN_STYLE_REL, &myButtonStyleREL); //set the relesed style
	lv_btn_set_style(autoWinAlly, LV_BTN_STYLE_PR, &myButtonStylePR); //set the pressed style
	lv_obj_set_size(autoWinAlly, 200, 50); //set the button size
	lv_obj_align(autoWinAlly, NULL, LV_ALIGN_IN_TOP_RIGHT, -10, 10); //set the position to top mid
	autoWinAllyLabel = lv_label_create(autoWinAlly, NULL); //create label and puts it inside of the button
	lv_label_set_text(autoWinAllyLabel, "Auto Win Ally"); //sets label text
	lv_obj_align(autoWinAllyLabel, NULL, LV_ALIGN_CENTER, 0, 0); //set the position to center
	autonOp = lv_btn_create(lv_scr_act(), NULL); //create button, lv_scr_act() is deafult screen object
	lv_obj_set_free_num(autonOp, 2); //set button is to 0
	lv_btn_set_action(autonOp, LV_BTN_ACTION_CLICK, btn_click_action); //set function to be called on button click
	lv_btn_set_style(autonOp, LV_BTN_STYLE_REL, &myButtonStyleREL); //set the relesed style
	lv_btn_set_style(autonOp, LV_BTN_STYLE_PR, &myButtonStylePR); //set the pressed style
	lv_obj_set_size(autonOp, 150, 50); //set the button size
	lv_obj_align(autonOp, NULL, LV_ALIGN_IN_BOTTOM_LEFT, 10, -10); //set the position to top mid
	autonOpLabel = lv_label_create(autonOp, NULL); //create label and puts it inside of the button
	lv_label_set_text(autonOpLabel, "Op"); //sets label text
	lv_obj_align(autonOpLabel, NULL, LV_ALIGN_CENTER, 0, 0); //set the position to center
	autonAlly = lv_btn_create(lv_scr_act(), NULL); //create button, lv_scr_act() is deafult screen object
	lv_obj_set_free_num(autonAlly, 3); //set button is to 0
	lv_btn_set_action(autonAlly, LV_BTN_ACTION_CLICK, btn_click_action); //set function to be called on button click
	lv_btn_set_style(autonAlly, LV_BTN_STYLE_REL, &myButtonStyleREL); //set the relesed style
	lv_btn_set_style(autonAlly, LV_BTN_STYLE_PR, &myButtonStylePR); //set the pressed style
	lv_obj_set_size(autonAlly, 150, 50); //set the button size
	lv_obj_align(autonAlly, NULL, LV_ALIGN_IN_BOTTOM_RIGHT, -10, -10); //set the position to top mid
	autonAllyLabel = lv_label_create(autonAlly, NULL); //create label and puts it inside of the button
	lv_label_set_text(autonAllyLabel, "Ally"); //sets label text
	skills = lv_btn_create(lv_scr_act(), NULL); //create button, lv_scr_act() is deafult screen object
	lv_obj_set_free_num(skills, 4); //set button is to 0
	lv_btn_set_action(skills, LV_BTN_ACTION_CLICK, btn_click_action); //set function to be called on button click
	lv_btn_set_style(skills, LV_BTN_STYLE_REL, &myButtonStyleREL); //set the relesed style
	lv_btn_set_style(skills, LV_BTN_STYLE_PR, &myButtonStylePR); //set the pressed style
	lv_obj_set_size(skills, 150, 50); //set the button size
	lv_obj_align(skills, NULL, LV_ALIGN_IN_BOTTOM_MID, 0, -10); //set the position to top mid
	skillsLabel = lv_label_create(skills, NULL); //create label and puts it inside of the button
	lv_label_set_text(skillsLabel, "Skills"); //sets label text
	lv_label_set_text(autonCurrent, "Current Auton: None");
	lv_obj_t * positionX = lv_label_create(lv_scr_act(), NULL); //create label and puts it on the middle of the screen
	int posX,posY;
	posX = 0;
	posY = 0;
	//print posX and posY
The error is caused at if id == 2, the other ids are for trying out different solutions.
