I would like to create a task like in the documentation in the example. However, that doesn’t work for me.
Error:
1.)
In function ‘void my_task(lv_task_t*)’:
NEW_TICK_BIB:19:32: error: invalid conversion from ‘void*’ to ‘uint32_t* {aka unsigned int*}’ [-fpermissive]
uint32_t * user_data = task->user_data;
ESP8266 / Arduino IDE
Latest
Create a task that work.
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <Ticker.h>
#define LVGL_TICK_PERIOD 20
Ticker tick; /* timer for interrupt handler */
void my_task(lv_task_t * task)
/*Use the user_data*/
printf("my_task called with user data: %d\n", *user_data);
static uint32_t user_data = 10;
lv_task_t * task = lv_task_create(my_task, 500, LV_TASK_PRIO_MID, &user_data);
void top_bar(void)
/*Create a Tab view object*/
lv_obj_t *tabview;
tabview = lv_tabview_create(lv_scr_act(), NULL);
/*Add 3 tabs (the tabs are page (lv_page) and can be scrolled*/
lv_obj_t *tab1 = lv_tabview_add_tab(tabview, "Home");
lv_obj_t *tab2 = lv_tabview_add_tab(tabview, "Auto");
lv_obj_t *tab3 = lv_tabview_add_tab(tabview, "Einstel.");
/*Add content to the tabs*/
static lv_color_t needle_colors[3];
needle_colors[0] = LV_COLOR_BLUE;
needle_colors[1] = LV_COLOR_ORANGE;
needle_colors[2] = LV_COLOR_PURPLE;
/*Create a gauge*/
lv_obj_t * gauge1 = lv_gauge_create(tab1, NULL);
lv_gauge_set_needle_count(gauge1, 3, needle_colors);
lv_obj_set_size(gauge1, 150, 150);
lv_obj_align(gauge1, NULL, LV_ALIGN_CENTER, 70, 0);
/*Set the values*/
lv_gauge_set_value(gauge1, 0, 10);
lv_gauge_set_value(gauge1, 1, 20);
lv_gauge_set_value(gauge1, 2, 30);
lv_obj_t * label;
lv_obj_t * label1;
lv_obj_t * btn1 = lv_btn_create(tab1, NULL);
lv_obj_align(btn1, NULL, LV_ALIGN_CENTER, -70, 40);
label = lv_label_create(btn1, NULL);
lv_label_set_text(label, "Start");
lv_obj_t * btn2 = lv_btn_create(tab1, NULL);
lv_obj_align(btn2, NULL, LV_ALIGN_CENTER, -70, -40);
label1 = lv_label_create(btn2, NULL);
lv_label_set_text(label1, "Stop");
#if USE_LV_LOG != 0
/* Serial debugging */
void my_print(lv_log_level_t level, const char * file, uint32_t line, const char * dsc)
Serial.printf("%s@%d->%s\r\n", file, line, dsc);
delay(100);
/* Display flushing */
uint16_t c;
tft.startWrite(); /* Start new TFT transaction */
tft.setAddrWindow(area->x1, area->y1, (area->x2 - area->x1 + 1), (area->y2 - area->y1 + 1)); /* set the working window */
for (int y = area->y1; y <= area->y2; y++) {
for (int x = area->x1; x <= area->x2; x++) {
c = color_p->full;
tft.writeColor(c, 1);
color_p++;
tft.endWrite(); /* terminate TFT transaction */
lv_disp_flush_ready(); /* tell lvgl that flushing is done */
/* Interrupt driven periodic handler */
static void lv_tick_handler(void)
/* Reading input device (simulated encoder here) */
bool read_encoder(lv_indev_drv_t * indev, lv_indev_data_t * data)
static int32_t last_diff = 0;
int32_t diff = 0; /* Dummy - no movement */
int btn_state = LV_INDEV_STATE_REL; /* Dummy - no press */
data->enc_diff = diff - last_diff;;
data->state = btn_state;
last_diff = diff;
return false;
void setup() {
#if USE_LV_LOG != 0
lv_log_register_print(my_print); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation(3); /* Landscape orientation */
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 320;
disp_drv.ver_res = 240;
disp_drv.buffer = &disp_buf;
/*Initialize the touch pad*/
lv_indev_drv_t indev_drv;
indev_drv.type = LV_INDEV_TYPE_ENCODER;
indev_drv.read_cb = read_encoder;
/*Initialize the graphics library's tick*/
tick.attach_ms(LVGL_TICK_PERIOD, lv_tick_handler);
void loop()
delay(5);
