I would like to invert the monochrome configuration so it has white widgets on a black background.
Is there an option to achieve this easily?
I can imagine three options:
- Change the colors in the your styles and/or the default styles. It might require some error and trial to see you did it correctly.
- Monochrome display controllers usually have an
invert
config option. - Invert all colors (bits) before sending it to the display controller.
Writing the inversion bit in the display controller was the easiest option Thankyou
