I use lv_timer_t *timer_countdown_update = lv_timer_create(countdown_update_UI, 100, NULL)
; to create a lv_timer. It can call countdown_update_UI()
per 100ms.
In countdown_update_UI()
, the msgbox obj are created in the first 100ms. msgbox obj is an obj with btn Yes, no close and a callback function.
, after waiting for 30 100ms, it will delete the obj by determining if the event code is LV_EVENT_DELETE
, if not it will call lv_msgbox_close(msgbox_timer_mode_drop)
In the callback function, If Yes btn triggers, it will delete the msgbox obj by determining if the event code is LV_EVENT_DELETE
The problem now is that at the 30th 100ms, Yes was pressed at the same time, probably because lv_msgbox_close()
was called twice, causing a reset.
Don’t call lv_msgbox_close ()
on an already closed message box object.
Set the message box object pointer to NULL
after the first call of lv_msgbox_close ()
Before you call lv_msgbox_close ()
check whether the message box object pointer is != NULL
Thank you for such a quick reply, now it won’t appear to reset, thanks a lot really!
