Button remains pressed
My problem is that if I press a key briefly, the key remains pressed and the letters repeat themselves on the keyboard, for example, without the key being pressed.
If I actually hold the key down, only a single entry is registered as desired.
Arduino Due/ Arduino IDE
latest
That the buttons do not stay pressed when pressed briefly
The logic in the touch function is reversed.
#include <lvgl.h>
//#include <lv_examples.h>
#include <UTFT.h>
#include <URTouch.h>
#include <Ticker.h>
#include <arduino-timer.h>
////////////////Globals/////////////////////77
uint32_t state_roller;
float value_spinbox1;
static void controls_create(lv_obj_t * parent);
static void visuals_create(lv_obj_t * parent);
static lv_obj_t * spinbox;
static lv_obj_t * gauge1;
static lv_color_t buf[LV_HOR_RES_MAX * 54];
void lv__tick_handler(void);
UTFT myGLCD(ITDB32S, 38, 39, 40, 41);
URTouch  myTouch( 6, 5, 4, 3, 2);
static void lv_spinbox_increment_event_cb(lv_obj_t * btn, lv_event_t e)
  if (e == LV_EVENT_SHORT_CLICKED || e == LV_EVENT_LONG_PRESSED_REPEAT)
    lv_spinbox_increment(spinbox);
    value_spinbox1 = lv_spinbox_get_value(spinbox);
    lv_gauge_set_value(gauge1, 0, value_spinbox1);
    Serial.println(value_spinbox1);
static void lv_spinbox_decrement_event_cb(lv_obj_t * btn, lv_event_t e)
    lv_spinbox_decrement(spinbox);
void gui(void)
  lv_obj_t *tabview;
  tabview = lv_tabview_create(lv_scr_act(), NULL);
  lv_obj_t *tab1 = lv_tabview_add_tab(tabview, "Home");
  lv_obj_t *tab2 = lv_tabview_add_tab(tabview, "Auto");
  lv_obj_t *tab3 = lv_tabview_add_tab(tabview, "Einstel.");
  ///////////////////////////Page_1(Home)//////////////////////////////////////
  static lv_color_t needle_colors[3];
    needle_colors[0] = LV_COLOR_BLUE;
    needle_colors[1] = LV_COLOR_ORANGE;
    needle_colors[2] = LV_COLOR_PURPLE;
  gauge1 = lv_gauge_create(tab1, NULL);
  lv_obj_set_size(gauge1, 150, 150);
  lv_obj_align(gauge1, NULL, LV_ALIGN_CENTER, 70, 0);
  //lv_gauge_set_value(gauge1, 0, value_spinbox1);
  lv_gauge_set_value(gauge1, 1, 20);
  //////////SPINBOX////////////
  spinbox = lv_spinbox_create(tab1, NULL);
  lv_spinbox_set_range(spinbox, 0, 100);
  lv_spinbox_set_digit_format(spinbox,3, 3);
  lv_spinbox_step_prev(spinbox);
  lv_obj_set_width(spinbox, 60);
  lv_obj_align(spinbox, NULL, LV_ALIGN_CENTER, -90, -50);
  lv_coord_t h = lv_obj_get_height(spinbox);
  lv_obj_t * btn = lv_btn_create(tab1, NULL);
  lv_obj_set_size(btn, h, h);
  lv_obj_align(btn, spinbox, LV_ALIGN_OUT_RIGHT_MID, 5, 0);
  lv_theme_apply(btn, LV_THEME_SPINBOX_BTN);
  lv_obj_set_style_local_value_str(btn, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, LV_SYMBOL_PLUS);
  lv_obj_set_event_cb(btn, lv_spinbox_increment_event_cb);
  btn = lv_btn_create(tab1, btn);
  lv_obj_align(btn, spinbox, LV_ALIGN_OUT_LEFT_MID, -5, 0);
  lv_obj_set_event_cb(btn, lv_spinbox_decrement_event_cb);
  lv_obj_set_style_local_value_str(btn, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, LV_SYMBOL_MINUS);
  //value_spinbox1=lv_spinbox_get_value(spinbox);
  //////////////////////PAGE_2////////////////////////////
  //////////////////Roller///////////////////////////////
  lv_obj_t *roller1 = lv_roller_create(tab2, NULL);
  lv_roller_set_options(roller1,
                        "Daimler\n"
                        "GM",
                        LV_ROLLER_MODE_NORMAL);
  lv_roller_set_visible_row_count(roller1, 4);
  lv_obj_align(roller1, NULL, LV_ALIGN_CENTER, -100, 0);
  lv_obj_set_event_cb(roller1, event_handler);
  state_roller = lv_roller_get_selected(roller1);
  //lv_obj_t *roller2 = lv_roller_create(tab2, NULL);
  //lv_obj_t *roller3 = lv_roller_create(tab2, NULL);
  if (state_roller == 0)
    lv_roller_set_options(roller2,
                          "Model 1\n"
                          "Model 2\n"
                          "Model 3",
    lv_roller_set_visible_row_count(roller2, 4);
    lv_obj_align(roller2, NULL, LV_ALIGN_CENTER, 0, 0);
    lv_obj_set_event_cb(roller2, event_handler);
  if (state_roller == 1)
    //lv_obj_del(roller2);
    lv_roller_set_options(roller3,
                          "ModelGM1\n"
                          "ModelGM2\n"
                          "ModelGM3",
    lv_roller_set_visible_row_count(roller3, 4);
    lv_obj_align(roller3, NULL, LV_ALIGN_CENTER, 100, 0);
    lv_obj_set_event_cb(roller3, event_handler);
  ///////////////////////////////////////Tastatur/////////////////////////////
  /*Create a keyboard and apply the styles*/
  lv_obj_t *kb = lv_keyboard_create(tab3, NULL);
  lv_keyboard_set_cursor_manage(kb, true);
  /*Create a text area. The keyboard will write here*/
  lv_obj_t *ta = lv_textarea_create(tab3, NULL);
  lv_obj_align(ta, NULL, LV_ALIGN_IN_TOP_MID, 0, LV_DPI / 16);
  lv_textarea_set_text(ta, "");
  lv_coord_t max_h = LV_VER_RES / 2 - LV_DPI / 8;
  if (lv_obj_get_height(ta) > max_h) lv_obj_set_height(ta, max_h);
  /*Assign the text area to the keyboard*/
  lv_keyboard_set_textarea(kb, ta);
/* Display flushing */
  myGLCD.drawBitmap(area->x1, area->y1, w , h, (bitmapdatatype)color_p, 1);
  lv_disp_flush_ready(disp);
/*Read the touchpad*/
bool my_touchpad_read(lv_indev_drv_t * indev_driver, lv_indev_data_t * data)
  uint16_t touchX, touchY;
  myTouch.read();
  int x = myTouch.getX();
  int y = myTouch.getY();
  bool touched = false;
  if ((x != -1) and (y != -1)) touched = true;
  if (!touched)
    data->point.x = x;
    data->point.y = y;
  return false; //Return `false` because we are not buffering and no more data to read
/* Reading input device (simulated encoder here) */
bool read_encoder(lv_indev_drv_t * indev, lv_indev_data_t * data)
  static int32_t last_diff = 0;
  int32_t diff = 0; /* Dummy - no movement */
  int btn_state = LV_INDEV_STATE_REL; /* Dummy - no press */
  data->enc_diff = diff - last_diff;;
  data->state = btn_state;
  last_diff = diff;
  return false;
void setup()
#if USE_LV_LOG != 0
  lv_log_register_print_cb(my_print); /* register print function for debugging */
  myGLCD.InitLCD();
  pinMode(8, OUTPUT);  //backlight
  digitalWrite(8, HIGH);//on
  myGLCD.clrScr();
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
  /*Initialize the display*/
  lv_disp_drv_t disp_drv;
  lv_disp_drv_init(&disp_drv);
  disp_drv.hor_res = 320;
  disp_drv.ver_res = 240;
  disp_drv.buffer = &disp_buf;
  /*Initialize the touch pad*/
  lv_indev_drv_t indev_drv;
  gui();
void timer_1(void)
  if (millis() % 5 > 1) //Every 5 ms
    lv_tick_inc(5);
void loop()
  timer_1();
  delay(4);
  if (event == LV_EVENT_VALUE_CHANGED) {
    char buf[32];
    lv_roller_get_selected_str(obj, buf, sizeof(buf));
    state_roller = lv_roller_get_selected(obj);
    printf("Selected Brand: %s\n", buf);
    printf("Selected at Roller1: %d\n", state_roller);
  if (!touched)
    data->point.x = x;
    data->point.y = y;
You need to provide the coordinates with LV_INDEV_STATE_PR, not LV_INDEV_STATE_REL.
Yes and data->state = LV_INDEV_STATE_PR musst be data->state = LV_INDEV_STATE_REL.
Thank you very much embedded!
