Button matrix showing rows as columns
I have designed a screen in EEZ studio (first screen shot) and it’s exactly how I want it to appear.
However when I upload to the display board it is displayed as per the second screen shot. What should be rows appear as columns.
Checked documentation tried extra row in button matrix.
This is the code for the matrix, labels that would normally be in the map are added afterwards as they change depending on item selected. Even with labels in the map the result is the same.
            lv_obj_t *obj = lv_btnmatrix_create(parent_obj);
            objects.function_mtx = obj;
            lv_obj_set_pos(obj, 7, 348);
            lv_obj_set_size(obj, 600, 122);
            static const char *map[12] = {
                "\n",
                NULL,
            static lv_btnmatrix_ctrl_t ctrl_map[10] = {
                1 | LV_BTNMATRIX_CTRL_CHECKABLE,
            lv_btnmatrix_set_map(obj, map);
            lv_btnmatrix_set_ctrl_map(obj, ctrl_map);
            lv_obj_set_style_pad_top(obj, 9, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_bottom(obj, 9, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_left(obj, 10, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_right(obj, 10, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_column(obj, 10, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_bg_color(obj, lv_color_hex(0xffc89600), LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_border_width(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_pad_row(obj, 10, LV_PART_MAIN | LV_STATE_DEFAULT);
            lv_obj_set_style_bg_color(obj, lv_color_hex(0xffffffff), LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_bg_grad_dir(obj, LV_GRAD_DIR_VER, LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_bg_grad_color(obj, lv_color_hex(0xff000000), LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_border_color(obj, lv_color_hex(0xff000000), LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_border_width(obj, 1, LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_text_color(obj, lv_color_hex(0xffffffff), LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_shadow_width(obj, 10, LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_shadow_ofs_x(obj, 5, LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_shadow_ofs_y(obj, 5, LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_shadow_spread(obj, 2, LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_shadow_color(obj, lv_color_hex(0xff000000), LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_shadow_opa(obj, 127, LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_text_font(obj, &lv_font_montserrat_16, LV_PART_ITEMS | LV_STATE_DEFAULT);
            lv_obj_set_style_bg_color(obj, lv_color_hex(0xffffff00), LV_PART_ITEMS | LV_STATE_CHECKED);
            lv_obj_set_style_shadow_width(obj, 0, LV_PART_ITEMS | LV_STATE_CHECKED);
            lv_obj_set_style_shadow_ofs_x(obj, 0, LV_PART_ITEMS | LV_STATE_CHECKED);
            lv_obj_set_style_shadow_ofs_y(obj, 0, LV_PART_ITEMS | LV_STATE_CHECKED);
            lv_obj_set_style_shadow_spread(obj, 0, LV_PART_ITEMS | LV_STATE_CHECKED);
            lv_obj_set_style_bg_grad_dir(obj, LV_GRAD_DIR_NONE, LV_PART_ITEMS | LV_STATE_CHECKED);
            lv_obj_set_style_text_color(obj, lv_color_hex(0xff000000), LV_PART_ITEMS | LV_STATE_CHECKED);
            lv_obj_set_style_bg_color(obj, lv_color_hex(0xffffff00), LV_PART_ITEMS | LV_STATE_PRESSED);
            lv_obj_set_style_bg_grad_dir(obj, LV_GRAD_DIR_NONE, LV_PART_ITEMS | LV_STATE_PRESSED);
            lv_obj_set_style_shadow_width(obj, 0, LV_PART_ITEMS | LV_STATE_PRESSED);
            lv_obj_set_style_shadow_ofs_x(obj, 0, LV_PART_ITEMS | LV_STATE_PRESSED);
            lv_obj_set_style_shadow_ofs_y(obj, 0, LV_PART_ITEMS | LV_STATE_PRESSED);
            lv_obj_set_style_shadow_spread(obj, 0, LV_PART_ITEMS | LV_STATE_PRESSED);
            lv_obj_set_style_text_color(obj, lv_color_hex(0xff000000), LV_PART_ITEMS | LV_STATE_PRESSED);
  • MCU/MPU/Board:
    Elecrow DIS02170A 7inch 800x480
    ESP32-S3-WROOM-1-N16R8
  • LVGL version: See lv_version.h
    LVGL 8.4
@RosscoeTrain , I create this keybord example with some styles. Maybe can help you.
    static lv_style_t style_base;
    static lv_style_t style_dark;
    static lv_style_t style_keys;
    static lv_style_t style_key_pressed;
    static lv_style_t style_key_checked;
    static bool style_inited = false;
    if (!style_inited) {
        lv_style_init(&style_base);
        lv_style_set_width(&style_base, 300);
        lv_style_set_height(&style_base, 200);
        lv_style_set_bg_color(&style_base, lv_color_hex(0xfafafc));
        lv_style_set_bg_opa(&style_base, 0);
        lv_style_set_pad_hor(&style_base, 24);
        lv_style_set_pad_top(&style_base, 38);
        lv_style_set_pad_bottom(&style_base, 25);
        lv_style_set_pad_column(&style_base, 10);
        lv_style_set_pad_row(&style_base, 10);
        lv_style_set_radius(&style_base, 0);
        lv_style_init(&style_dark);
        lv_style_set_bg_color(&style_dark, lv_color_hex(0x121212));
        lv_style_init(&style_keys);
        lv_style_set_bg_color(&style_keys, lv_color_hex3(0xfff));
        lv_style_set_bg_opa(&style_keys, 255);
        lv_style_set_radius(&style_keys, 20);
        lv_style_set_shadow_offset_y(&style_keys, 2);
        lv_style_set_shadow_color(&style_keys, lv_color_hex(0x000000));
        lv_style_set_shadow_opa(&style_keys, (255 * 10 / 100));
        lv_style_set_shadow_spread(&style_keys, 0);
        lv_style_set_shadow_width(&style_keys, 20);
        lv_style_init(&style_key_pressed);
        lv_style_set_bg_color(&style_key_pressed, lv_color_hex(0xb3b1b1));
        lv_style_set_bg_opa(&style_key_pressed, 255);
        lv_style_init(&style_key_checked);
        lv_style_set_bg_color(&style_key_checked, lv_color_hex(0xff00ff));
        style_inited = true;
    lv_obj_t * lv_obj_0 = lv_obj_create(NULL);
    lv_obj_set_name_static(lv_obj_0, "screen_main_#");
    lv_obj_set_style_bg_color(lv_obj_0, G_BG_COLOR, 0);
    lv_obj_t * lv_keyboard_0 = lv_keyboard_create(lv_obj_0);
    lv_keyboard_set_mode(lv_keyboard_0, LV_KEYBOARD_MODE_NUMBER);
    lv_obj_add_style(lv_keyboard_0, &style_base, 0);
    lv_obj_add_style(lv_keyboard_0, &style_keys, LV_PART_ITEMS);
    lv_obj_add_style(lv_keyboard_0, &style_key_checked, LV_PART_ITEMS | LV_STATE_CHECKED);
    lv_obj_add_style(lv_keyboard_0, &style_key_pressed, LV_PART_ITEMS | LV_STATE_PRESSED);
