I have a topic post on building micropython codebase with eclipse on the micropython forum here and it works.
However when I try the same method for lv_micropython (driver_STM32F7DISC branch) here https://github.com/prolomb/lv_micropython.git , just in the beginning of the build process (where the mainline micropython stm32 build process normally pass with “python3 …/…/py/makeversionhdr.py build-STM32F7DISC/genhdr/mpversion.h”) I get “FIND: Parameter format not correct” 11 times like this:
15:02:19 **** Build of configuration Default for project lv_micropython ****
make -C ports/stm32 V=1 BOARD=STM32F7DISC
make: Entering directory 'I:/microPython-500gb/lv_micropython/ports/stm32'
GEN build-STM32F7DISC/genhdr/pins.h
python3 boards/make-pins.py --board boards/STM32F7DISC/pins.csv --af boards/stm32f746_af.csv \
--prefix boards/stm32f4xx_prefix.c --hdr build-STM32F7DISC/genhdr/pins.h --hdr-obj-decls \
--qstr build-STM32F7DISC/pins_qstr.h --af-const build-STM32F7DISC/genhdr/pins_af_const.h \
--af-defs build-STM32F7DISC/genhdr/pins_af_defs.h --af-defs-cmp-strings \
--af-py build-STM32F7DISC/pins_af.py > build-STM32F7DISC/pins_STM32F7DISC.c
I am pretty sure that quotes (" ") are required somewhere because in windows find requires quotes
FIND something
FIND "something"
works
however I can’t locate which command cause this error in stm32/Makefile.
I appreciate your help. Thanks
EDIT
At the end I get a “OSError: [WinError 193] %1 is not a valid Win32 application” error as well, this can be connected with FIND error above.
python3 ../../tools/makemanifest.py -o build-STM32F7DISC/frozen_content.c -v "MPY_DIR=../.." -v "MPY_LIB_DIR=../../../micropython-lib" -v "PORT_DIR=/i/microPython-500gb/lv_micropython/ports/stm32" -v "BOARD_DIR=boards/STM32F7DISC" -b "build-STM32F7DISC" -f"-march=armv7m" boards/manifest.py
MPY dht.py
File "../../tools/makemanifest.py", line 294, in <module>
main()
File "../../tools/makemanifest.py", line 254, in main
res, out = system([MPY_CROSS] + args.mpy_cross_flags.split() + ['-o', outfile, '-s', script, '-O{}'.format(opt), infile])
File "../../tools/makemanifest.py", line 126, in system
output = subprocess.check_output(cmd, stderr=subprocess.STDOUT)
File "C:\Users\murat\AppData\Local\Programs\Python\Python37\Lib\subprocess.py", line 395, in check_output
**kwargs).stdout
File "C:\Users\murat\AppData\Local\Programs\Python\Python37\Lib\subprocess.py", line 472, in run
with Popen(*popenargs, **kwargs) as process:
File "C:\Users\murat\AppData\Local\Programs\Python\Python37\Lib\subprocess.py", line 775, in __init__
restore_signals, start_new_session)
File "C:\Users\murat\AppData\Local\Programs\Python\Python37\Lib\subprocess.py", line 1178, in _execute_child
startupinfo)
make: *** [../../py/mkrules.mk:103: build-STM32F7DISC/frozen_content.c] Error 1
make: Leaving directory 'I:/microPython-500gb/lv_micropython/ports/stm32'
"make -C ports/stm32 V=1 BOARD=STM32F7DISC" terminated with exit code 2. Build might be incomplete.
15:07:31 Build Failed. 1 errors, 0 warnings. (took 5m:11s.295ms)
