Bug in Button ink out time
Ink Out effect time is not getting set correctly.
Simulator
What do you experience?
So, I am writing unit tests in my serialization and ink out time is not being set.
What do you expect?
Ink out time being set correctly.
Bug is here, line 340 in lv_btn.c:
uint16_t lv_btn_get_ink_out_time(const lv_obj_t * btn)
#if LV_USE_ANIMATION && LV_BTN_INK_EFFECT
    lv_btn_ext_t * ext = lv_obj_get_ext_attr(btn);
    return ext->ink_in_time;                            <<<<<<< ERROR
#else
    (void)btn; /*Unused*/
    return 0;
ink_in_time is being returned when it should be ink in
Use the ```c and ``` tags to format your code:
If possible, add screenshots and/or videos about the current issue.
Thanks, I fixed it here.
Gracias. I suppose its one good side effect of my gui project. Since I am also writing serialization, I am ending up writing unit tests the essentially test nearly all LVGL properties.
That’s awesome! :slight_smile:
There is another topic about unit tests. Maybe there are some common points.
Oh, I am sure. When I get this all done, maybe we can add it as a checkin gate (The unit tests).
