Best practice to make a multi screen application
Hi…
If I’d like use lot of screens and all of them has more objects, then need create diferent objects on every screen.
When closing a screen need to delete object, and so on …
I’d to create a stru for every screens, that holds objects.
After init I don’t want to delete them to prevent fregmantatoin.
But I cant find function to disable or hide objects.
How is best methode to change used object in a current screen from initialized struct of object.
May be put all objects into container and call set_hidden of container?
What about the overhead and speed that cause the above methode?
Can I find a similar sample project ?
Thanks…
Simulator at the moment…later ST32Fxxx and ESP32
Experince with lvgl… :slight_smile:
Lot of things…:grinning:
It’s explained in the documentation here.
