This is my driver code , Could you please suggest where should i put this color print to check the color value for 16bppâŚ
#include âfbdev.hâ
#if USE_FBDEV || USE_BSD_FBDEV
#include <stdlib.h>
#include <unistd.h>
#include <stddef.h>
#include <stdio.h>
#include <fcntl.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
#if USE_BSD_FBDEV
#include <sys/fcntl.h>
#include <sys/time.h>
#include <sys/consio.h>
#include <sys/fbio.h>
#else /* USE_BSD_FBDEV /
#include <linux/fb.h>
#endif / USE_BSD_FBDEV */
#ifndef FBDEV_PATH
#define FBDEV_PATH â/dev/fb0â
struct bsd_fb_var_info{
uint32_t xoffset;
uint32_t yoffset;
uint32_t xres;
uint32_t yres;
int bits_per_pixel;
struct bsd_fb_fix_info{
long int line_length;
long int smem_len;
- STATIC PROTOTYPES
- STATIC VARIABLES
#if USE_BSD_FBDEV
static struct bsd_fb_var_info vinfo;
static struct bsd_fb_fix_info finfo;
#else
static struct fb_var_screeninfo vinfo;
static struct fb_fix_screeninfo finfo;
static char *fbp = 0;
static long int screensize = 0;
static int fbfd = 0;
- GLOBAL FUNCTIONS
void fbdev_init(void)
// Open the file for reading and writing
fbfd = open(FBDEV_PATH, O_RDWR);
if(fbfd == -1) {
perror(âError: cannot open framebuffer deviceâ);
return;
printf(âThe framebuffer device was opened successfully.\nâ);
#if USE_BSD_FBDEV
struct fbtype fb;
unsigned line_length;
//Get fb type
if (ioctl(fbfd, FBIOGTYPE, &fb) != 0) {
perror("ioctl(FBIOGTYPE)");
return;
//Get screen width
if (ioctl(fbfd, FBIO_GETLINEWIDTH, &line_length) != 0) {
perror("ioctl(FBIO_GETLINEWIDTH)");
return;
vinfo.xres = (unsigned) fb.fb_width;
vinfo.yres = (unsigned) fb.fb_height;
vinfo.bits_per_pixel = fb.fb_depth + 8;
vinfo.xoffset = 0;
vinfo.yoffset = 0;
finfo.line_length = line_length;
finfo.smem_len = finfo.line_length * vinfo.yres;
#else /* USE_BSD_FBDEV */
// Get fixed screen information
if(ioctl(fbfd, FBIOGET_FSCREENINFO, &finfo) == -1) {
perror("Error reading fixed information");
return;
// Get variable screen information
if(ioctl(fbfd, FBIOGET_VSCREENINFO, &vinfo) == -1) {
perror("Error reading variable information");
return;
#endif /* USE_BSD_FBDEV */
printf("%dx%d, %dbpp\n", vinfo.xres, vinfo.yres, vinfo.bits_per_pixel);
// Figure out the size of the screen in bytes
screensize = finfo.smem_len; //finfo.line_length * vinfo.yres;
// Map the device to memory
fbp = (char *)mmap(0, screensize, PROT_READ | PROT_WRITE, MAP_SHARED, fbfd, 0);
if((intptr_t)fbp == -1) {
perror("Error: failed to map framebuffer device to memory");
return;
memset(fbp, 0, screensize);
printf("The framebuffer device was mapped to memory successfully.\n");
void fbdev_exit(void)
close(fbfd);
Flush a buffer to the marked area
@param drv pointer to driver where this function belongs
@param area an area where to copy color_p
@param color_p an array of pixel to copy to the area
part of the screen
void fbdev_flush(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p)
if(fbp == NULL ||
area->x2 < 0 ||
area->y2 < 0 ||
area->x1 > (int32_t)vinfo.xres - 1 ||
area->y1 > (int32_t)vinfo.yres - 1) {
lv_disp_flush_ready(drv);
return;
/Truncate the area to the screen/
int32_t act_x2 = area->x2 > (int32_t)vinfo.xres - 1 ? (int32_t)vinfo.xres - 1 : area->x2;
int32_t act_y2 = area->y2 > (int32_t)vinfo.yres - 1 ? (int32_t)vinfo.yres - 1 : area->y2;
lv_coord_t w = (act_x2 - act_x1 + 1);
long int location = 0;
long int byte_location = 0;
unsigned char bit_location = 0;
/32 or 24 bit per pixel/
if(vinfo.bits_per_pixel == 32 || vinfo.bits_per_pixel == 24) {
uint32_t * fbp32 = (uint32_t *)fbp;
int32_t y;
for(y = act_y1; y <= act_y2; y++) {
location = (act_x1 + vinfo.xoffset) + (y + vinfo.yoffset) * finfo.line_length / 4;
memcpy(&fbp32[location], (uint32_t *)color_p, (act_x2 - act_x1 + 1) * 4);
color_p += w;
/16 bit per pixel/
else if(vinfo.bits_per_pixel == 16) {
uint16_t * fbp16 = (uint16_t *)fbp;
int32_t y;
location = (act_x1 + vinfo.xoffset) + (y + vinfo.yoffset) * finfo.line_length / 2;
memcpy(&fbp16[location], (uint32_t *)color_p, (act_x2 - act_x1 + 1) * 2);
color_p += w;
/8 bit per pixel/
else if(vinfo.bits_per_pixel == 8) {
uint8_t * fbp8 = (uint8_t *)fbp;
int32_t y;
location = (act_x1 + vinfo.xoffset) + (y + vinfo.yoffset) * finfo.line_length;
memcpy(&fbp8[location], (uint32_t *)color_p, (act_x2 - act_x1 + 1));
color_p += w;
/1 bit per pixel/
else if(vinfo.bits_per_pixel == 1) {
uint8_t * fbp8 = (uint8_t )fbp;
int32_t x;
int32_t y;
for(x = act_x1; x <= act_x2; x++) {
location = (x + vinfo.xoffset) + (y + vinfo.yoffset) * vinfo.xres;
byte_location = location / 8; / find the byte we need to change /
bit_location = location % 8; / inside the byte found, find the bit we need to change */
fbp8[byte_location] &= ~(((uint8_t)(1)) << bit_location);
fbp8[byte_location] |= ((uint8_t)(color_p->full)) << bit_location;
color_p++;
color_p += area->x2 - act_x2;
} else {
/Not supported bit per pixel/
//May be some direct update command is required
//ret = ioctl(state->fd, FBIO_UPDATE, (unsigned long)((uintptr_t)rect));
void my_set_px_cb(struct _disp_drv_t * disp_drv, uint8_t * buf, lv_coord_t buf_w, lv_coord_t x, lv_coord_t y, lv_color_t color, lv_opa_t opa)
buf += buf_w/8 * y;
buf += x/8;
if(lv_color_brightness(color) > 128) {(*buf) |= (1 << (7 - x % 8));}
else {(*buf) &= ~(1 << (7 - x % 8));}
void my_rounder(struct _disp_drv_t * disp_drv, lv_area_t *a)
a->x1 = a->x1 & ~(0x7);
a->x2 = a->x2 | (0x7);
