So, I’m pleased to introduce my new project “emToile” which is a (partially) implementation in C++ of Lvgl framework targeting Arduino ecosystem. I made it to share easily GUI code b/w my Lilygo’s TWatch and LilyPI.
For the moment, only a subset of Lvgl’s objects are covered but it will increase as per my need. Obviously, everyone is welcome to join the journey
Bye
emToile is evolving (slowly ) as per the improvements needed by DomoWatch project.
I did a massive redesign to emancipate Styles vs object to be more in line with LVGL’s way of working.
Styles are now fully converted, object local styles are only partially.
I have added also some (few) example.
As example :
Simple chart :
#include <Chart.h>
* objects
Chart *chart;
Chart::Serie *serie;
* Build the chart
void start_gui( void ){
/* Create the chart */
chart = new Chart( 10, lv_scr_act() );
chart->setSize( 300, 200 );
chart->Align( LV_ALIGN_CENTER );
chart->setCaptionString( "Chart example" );
/* Add ticks on the left */
chart->setPadding( 5, 5, 4 * (LV_DPI / 10), 0, LV_CHART_PART_BG ); // set space on the left
chart->yTicks( "600\n500\n400\n300\n200" );
/* Add data series */
serie = chart->addSerie( LV_COLOR_RED );
serie->Insert( 0 );
serie->Insert( 10 );
serie->Insert( 20 );
serie->Insert( 40 );
serie->Insert( 60 );
serie->Insert( 70 );
serie->Insert( 90 );
serie->Insert( 100 );
Bye
Is emToile actually a C++ binding for LVGL?
Yes, it is (Binding and not building … but I don’t know how to modify the title )
But for the moment, only a subset as per my needs.
Here a more complete example with a Chart and some styles and DomoWatch is a full featured appli.
Ah cool. I’ve modified the title.
We were thinking for a long about a C++ binding but I think it’d be more maintainable if the binding were auto-generated.
The Micropython binding generated a JSON file with the API of LVGL.
Seemingly it could be a good starting point. lv_mpy_example.json.zip (139.4 KB) .
What do you think about it?
Thanks for the title
For auto-generation, it’s definitively a must for classes having lot of methods like Styles or root objects.
But at a moment or another, manual changes are required for example to specify default values (one of the BIG added value of C++, IMO).
But for others, manual implementation leads to a better POO design : as example, Chart where Series are a sub class of Chart.
And it’s part of my knowledge ramp-up on LVGL
So all in all, probably an hybrid method would be the best :
- automatic for styles, root objects which are very tedious to implement,
- Manual for high level ones.
In fact, it’s depending of the downward compatibility b/w versions and as I worked only on 7.x, I haven’t any clue this aspect.
v8 is not backward compatible but minor versions are. Major versions are added only in 1-2 years.
