Operating system and interrupts
LittlevGL is not thread-safe by default.
However, in the following conditions it’s valid to call LittlevGL related functions:
Tasks and threads
If you need to use real tasks or threads, you need a mutex which should be invoked before the call of lv_task_handler
and released after it. Also, you have to use the same mutex in other tasks and threads around every LittlevGL ( lv_...
) related function calls and codes. This way you can use LittlevGL in a real multitasking environment. Just make use of a mutex to avoid the concurrent calling of LittlevGL functions.
Interrupts
Try to avoid calling LittlevGL functions from the interrupts (except lv_tick_inc()
and lv_disp_flush_ready()
). But, if you need to do this you have to disable the interrupt which uses LittlevGL functions while lv_task_handler
is running. It’s a better approach to set a flag or some value and periodically check it in an lv_task
I think there should be have a example to show HOW.
