I am using K210 from kendryte. I am using v6.02
What do you experience?
I’ve created a page and then added two ddlist in the Page. When I press the second ddlist I expect that the page scrollbar move to the ddlist so I can see all the ddlist options but this doesn’t happen and I need to scroll down manually
What do you expect?
void test_ddlist_in_page() {
lv_obj_t * value_obj = NULL;
lv_obj_t *prev_value_obj = NULL;
lv_obj_t * bg = lv_page_create(lv_scr_act(), NULL);
// lv_obj_set_pos(bg, PADDING_BORDER, lv_obj_get_y(obj)+ PADDING_BORDER);
//lv_page_set_scrl_fit4(bg, LV_FIT_FILL, LV_FIT_FILL, LV_FIT_FLOOD,LV_FIT_FILL);
lv_obj_set_size(bg, LV_HOR_RES_MAX - 120, 150);
lv_page_set_style(bg, LV_PAGE_STYLE_SCRL, &lv_style_transp_tight);
lv_page_set_style(bg, LV_PAGE_STYLE_BG, &lv_style_transp_tight);
lv_obj_align(bg, NULL, LV_ALIGN_IN_TOP_LEFT, 0, 0);
value_obj = lv_ddlist_create(bg, NULL);
lv_ddlist_set_options(value_obj, "320x240\n480x320\n640x480\n800x600\n1280x720\n1920x1080\n1280x960\n2592x1944");
lv_ddlist_set_fix_width(value_obj, 160);
lv_ddlist_set_fix_height(value_obj, 150);
lv_ddlist_set_draw_arrow(value_obj, true);
lv_obj_align(value_obj, NULL, LV_ALIGN_IN_TOP_LEFT, 10, 10);
prev_value_obj = value_obj;
lv_ddlist_set_options(value_obj, "auto\nsunny\noffice\ncloudy\nhome");
lv_ddlist_set_fix_width(value_obj, 150);
lv_obj_align(value_obj, prev_value_obj, LV_ALIGN_OUT_BOTTOM_LEFT, 0, 30);
If possible, add screenshots and/ or videos about the current issue.
