As far as I know, the current task has a single execution function void lv_task_once(lv_task_t * task);.
* Descriptor of a lv_task
typedef struct _lv_task_t
uint32_t period; /**< How often the task should run */
uint32_t last_run; /**< Last time the task ran */
lv_task_cb_t task_cb; /**< Task function */
void * user_data; /**< Custom user data */
uint8_t prio : 3; /**< Task priority */
uint8_t once : 1; /**< 1: one shot task */
} lv_task_t;
* Delete the lv_task after one call
* @param task pointer to a lv_task.
But sometimes we need to control the times of tasks to be execute .
Maybe more than once.
Therefore, I think it can be simply modified to achieve the purpose.
//uint8_t once : 1; /**< 1: one shot task */
int32_t time; /**< 1: Task times; -1 : infinity; 0 : stop ; n>0: residual times */
} lv_task_t;
Couldn’t you just enable and disable the task within your application? You could call lv_task_set_prio(task, LV_TASK_PRIO_OFF) after it’s been run several times. I think that would be simpler.
Has this been solved? I am dealing with a similar situation where I want to stop a task after x times instead of only 1.
Imagine that I press a button and that button activates a task. After that I am not doing anything else, the only code running is the task code and I really want it to stop after 10 times. Since I can’t, from inside the function, to tell it to stop, I can’t call lv_task_set_prio(task, LV_TASK_PRIO_OFF).
Any workaround? Thanks! (btw I am using micropython).
So never mind what I right above, if you are using a task with lambdas you can actually pass your task handler as an argument and use it from inside the CB function. Then inside the CB function you can call lv.task_set_prio(task, lv.TASK_PRIO.OFF). The downside is that you need to have a global tracking the number of times that your function was called and remember to reset the global if you interrupt the task somewhere else (or to reset it to 0 before you start the task)
An approach like @ShenRen suggested would be cleaner and more user friendly. But I understand if this is not a priority.
Example:
global CALLS
CALLS = 0
task = lv.task_create(lambda task: your_cb_function(task, ...), 500, lv.TASK_PRIO.HIGH, None)
def your_cb_function(task,...):
global CALLS
if CALLS == 10:
CALLS = 0
else:
CALLS+=1
