ESP32 on ESP-IDF 4.2 +littleVGL 6.0
a setting windows with a SAVE button. When clic on SAVE, … run saving function…
but local variable in the event is only related to SAVE button, NOT the settings objects. Then event cannot get objects (settings) values. then cannot save.
i tried to put some settings objects of my win in static “global” variable : it work (can get value from click-saveButton-event), but did i really have to put ALL my objects in global variables to access it from events ??? seems to be not an ideal way to do…
another idea is to make a loop test in the “building widows function” (there all objets are local variable, then accessible) over a static “status” variable. … if (status ==1) { disable save button & make save actions }
Then, change global “status” variable into clic button event…
probably cleaner, cause all object stay local, then will be really free from memory when destroy parent object. otherwise, if all is global variable, it continue to consume this memory…
It’s probably a VERY common problem… How do you do this kind of actions ?
