Slow rendering when streaming a video using image object
Hi @kisvegabor,
Thanks for the reply, ill check out the FFmpeg feature and see if that also helps.
I figured out the mistake I had made in my code by referring to this post. I created a new image object on each RTSP frame received instead of just calling the lv_obj_invalidate after updating the source. Now I can see better rendering with some delay around 500-600ms.
Do you suggest FFmpeg will give better results?
Thanks again,
Fakhruddin
